Yokomo MR-4TC SD
Hey guys do you know if someone makes Aluminum diff out drives or after market diff pulleys for the BD car?
Originally Posted by JayBee
When you first built the shocks, did they have rebound, were they 'dead' or did the piston and shaft suck up into the body? -JB
ill try and get pics later tonight.....what kind of pics would help?
Originally Posted by pops
I really meant if they would hold up in mod, or are they too weak for regular racing, since they are advertised for drift.
Ehmmm, let's give it a try.
Originally Posted by thisisagame24
originally it would just sink to where the chassis was sitting on the ground....but now it will stay up for like 1-2 seconds and then sink
This may sound like a stupid question, but you say the chassis stays up 1 or 2 seconds, then it sinks to the ground. Do you have springs installed on the shocks? have you tightened down the collars on the shocks to compress the springs?
Do all 4 shocks react the same?
so i looked at the manual, when you say theres nothing to slow the shock down, you meant theres no shock oil? i see directions for building the shocks on page 19. did you see the note where it said, "shaded parts are not used" that means you should have #3 pistons and the LONG shock ends on. if you used the short ends then the car will probably sit on the table. did the shocks come with "spacer rings" to adjust spring tention?
ok,i lost a king pin.does anyone know if other king pins will fit the mr4tc?the reason being,yokomo in hawaii is kinda rare.thanx in advance
thisisagame24,
there are two type of shock end, AL(long) & AS(short), the instruction calls for the AL shock ends. If you use the AS, your shocks will be too short and the car sits too low, eg. chassis touching the ground. Please double check you use the right shock ends.
Originally Posted by caveman
thisisagame24,
im not sure if the drift car has droop screws. but if it has check that they havent been screwed down to far, so that they limit the ride height you can get.
might not be it, but cant harm trying.
thanks
thanks
thanks
thanks
has anyone else had this problem with these shocks?????
i am using the right shock end...i made sure of that...that was one of the first things i checked out
the thing i notice is the lack of spring spacers. how are you suppose to adjust ride height,
one more thing, i assume you have the wheels and tires on.
yea i noticed that there werent any spacers either but there are droop screws to adjust the ride hight
well i finally got it working...i had the number 2 pistons in instead of three....but the fronts were still soft has hell so i took the spacer clips from my hpi rs4 and threw them on and they work great....thanks for all of your help guys
