Yokomo MR-4TC SD
guys,
I need some help on balancing the ride height and tweak.
everytime after i set up the ride height on the car(6mm), i put it on the tweak station and adjusting the tweak side to side. I notice my ride height changes a lot from what i started(4.5mm~5mm from 6mm). that is a lot of change in ride height.
I know i'm doing something wrong. any help would be appreciated.
Thanks,
Ming
Thanks,
Ming
OK Guys it is offical I am selling my LCG. I ran it yesterday and it was very fast and had lots of steering. It was on rails and drove so very nice. However I am very happy with my RDX and found I don't have time for two different cars to try and setup and practice with, SO I am selling my LCG.
I am asking $365.00 shipped to the lower 48 states.
PM me for the details of what you would get.
Thanks Guys,
-SHookie <><
Thanks Guys,
-SHookie <><
-SHookie <><
-SHookie <><
MR SHOOKIE
Can you please PM me your current setup of your LCG.
Calvin.
Calvin.
Originally Posted by Pro4Capece
Why would you sell the LCG if it is on rails? Is your RDX on rails? If they both are, then you don't need to spend you time setting up both cars, they are already setup.
Yes the RDX is on rails,
Yes the LCG is on rails,
Yes I would have to spend time on setup as each car
Every track I go to is a little bit different and I do not have time to practice both cars because each car handles different for each track.
Plus I would rather focus all my energy into one car. I have a hard enough time getting one car ready the night before a race, could you amagine two...Sheesh not me, not anymore.
Secondly,
I like how consistant I am with a belt car. That is mainly the reason why I am not running a shaft car anymore.
Although I am keeping my Rayspeed for when I go to mexico for missions trips to entertain the children. I still like Yokomo I am not some hater or anything just that I found a better car that works for me.
-Shookie <><
New steering rack
Looks like Yokomo will release a new steering rack for the LCG....
-Dave
-Dave
LCG Steering Rack
-Dave
-Dave
Dave,
When will it be released? Also, where did you find this pic(proto?)?
Trader Rating: 27 (100%+)
hey guys im a experienced nitro driver going to electric and im going to pick up a yokomo cgm. i would like to know what you guys think of the car?
Hi,
the CGM is a very nice car. I owned one that I converted to the LCG and now I bought a second because I really like the car. It's great on carpet but you can race it on asphalt aswell... I tried it a few times and was a real fun... especially with foams... If you race on asphalt try to get a LCG... It handles great on carpet and it's fast... it's just not as agressive as the CGM...
Cheers
Chris
Cheers
Chris
Originally Posted by speedy-932
Hi,
Cheers
Chris
Cheers
Chris
-Dave
-Dave
"Hurt" is a hard word... It depends on your driving style and what you like. I like agressive cars... the CGM is a very agressive car... but I loose a bit of corner speed because it doesn't roll enough for me... the LCG "flows" more... not as agressive as the CGM but more constant and faster... I really like the car and if you set it up correctly it will be very competitive on carpet aswell... Don't worry...
Cheers
Chris
Cheers
Chris
Does the chassis flex hurt the LCG on carpet?
Maybe mine flexes more than normal. I get more flex with this car than any other car I've ever seen or held. I can hold the shock towers and twist the chassis a good bit in each direction. I can't even make an FK05 budge using the same twisting technique. I was under the impression that a stiffer chassis is needed to keep the car from biting in the turns.
That might be why the LCG is a crazy fast car on asphalt.
Yes, it flexes a lot... more then any other car I've seen...
This was my impression on carpet... It rolls more then the CGM... If you have a carpet track in your region, go there and test it yourself...
I think it's no problem to make a stiffer chassis... it's just the money... 3.5mm lower deck and 3mm upperdeck made of bilinear CFK... that's stiff... Or you put the steering posts of the CGM between the upper deck and the steering rack... fits perfectly... I just don't have a long enough screw in my pit box to try if it will really help...
Cheers
Chris
Cheers
Chris
Originally Posted by aoizip
guys,
Thanks,
Ming
Thanks,
Ming
Re-install the shocks, measure the droop, put your tires back on and measure the ride height. With a hobby knife lift the front end of the car up, the front tires should lift off the board at the same time, if they don't adjust the shock collars on the rear of the car until they do. Do the same thing to the rear of the car by adjusting the front shock collars. Once everything is equal, re-adjust the ride height to about 5mm a good starting point.
Someone at your track should be able to help you with this. I have a MIP Tweak Station and if you know anybody who wants one, it is for sale.
