Yokomo MR-4TC SD
Originally Posted by agower
i really cant think of anything else that it could be, what springs are you using and are you using the blue alloy rayspeed spring retainers that you HAVE to use? are you using the lower hole on each on all hubs?
ill post a pic of my car to show you at the rear becuase its easier to see.
I will wait for u to post pics. I'm using the rayspeed spring w/ the aluminim retainers. The hubs are set to factory specs(lower hole).
do you actualy have a lcg dan?
also what positions have you got the shocks on? on the wishbone and on the suspesnion arm? i have no spacers under any of the suspension mounts apart front the front front so i have some kick up.
i really cant think of anything else, i am sitting hear looking at it so i can see anything.
so if this is no help
A Gower
A Gower
I dont have one but im just trying to run through the things that could be causing the problems. When i get some more money together (just splashed out on a BD) i will convert my SSG into a LCG. Blindwolf are you running foams?
Could someone please tell me the exact length of the motor clamp spring on a CGM when it is not compressed please. This is not a wind up
Cheers in anticipation
7.4mm my friend.
Thank you very much indeed
Malc
Cool-Can-Fan's Rule
Malc
Cool-Can-Fan's Rule
Originally Posted by blindwolf
hi shookie,
I tried the spacers under the suspension mounts to no avail. I'm at 6.5(front) and 7.5(rear) in height. When i lift the front end and wiggle the spring it is sloppy, same with the rear.This sloppy wobble is not supposed to be there correct? I'm so frustrated! Someone please have one of the Yokomo guys post pic with setup ex; Dampers(long or short body) yadda,yadda. Just something visual and written for me to grasp. I'm about 2 throw in the towel.
Malc
Cool-Can-Fan's Rule
Malc
Cool-Can-Fan's Rule
Thanks in advance
Stephen <><
Originally Posted by pops
Do you have the spring retainers upside down?
hi shookie,
Originally Posted by daniz24
Try to remove your ball cups first and then see the suspension arm movement. Are using o-ring inside the rear diff? Or are you using the correct universal bones (ZS-010RTB Rear Low Friction Aluminum Dogbone Blue 1pc/pack)
Originally Posted by Matt Howard
I see you're from Norcal, if you still can't figure it out then bring your car to Speedworld Raceway this weekend have pops (russ siemantel), John Scott, or Noah Ramos look at it for you. They're all Yokomo sponsored drivers and should be attending the Speedworld Cup this weekend.
hi shookie,
Originally Posted by Turtlemaster
if you put spacers under the suspension mounts you are moving the arms closer to the shock tower and this will raise ride height.
