Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-26-2008, 06:21 PM   #1351
bboy's Avatar
Cool, appreciate it. Looks like you directly solder the wires to the batteries, or are you using the bananas?
Serpent 960-08 + Max XL9
XRay NT1 + Max XXL3
CRC Gen-X + Novak Brushless 4.5
bboy is offline   Reply With Quote
Old 07-26-2008, 08:39 PM   #1352
odpurple's Avatar
Plugs? Never!! I use a half battery bar as a solder lug on the battery
odpurple is offline   Reply With Quote
Old 07-28-2008, 01:41 AM   #1353
auzzy_mate's Avatar
Default Gearing
I have just picked up a used (but still in top condition) 1/12 Gen X. Yah me!
As it has not been delivered yet I was wondering what the pitch of the gears was: 64 or 48?
auzzy_mate is offline   Reply With Quote
Old 07-28-2008, 04:51 AM   #1354
TaJoe5's Avatar
Send a message via AIM to TaJoe5
Should be 64 pitch
OHP Batteries and Motors, http://www.ohiohobbyplus.com/
Razor Graphix, Team Losi Type-R, Tamiya EVO-IV, CRC Gen X
The Coliseum at HobbyTown USA, Fredrick MD the original indoor asphalt track of MD and home of the 2009 Asphalt Nationals :oP
TaJoe5 is offline   Reply With Quote
Old 08-01-2008, 09:08 AM   #1355
johnnywhopper's Avatar
new lowered "map" price for the Gen-X for the 08-09 carpet season.
224.99!
http://www.teamcrc.com/crc/modules.p...prodID=7718906
Team CRC, Power Push, Parma, IRS, G2 Designs, Moby Graphix, Putnam Propulsion, Black Art, Smyka's Hotel & Casino - Broad Brook, CT
johnnywhopper is offline   Reply With Quote
Old 08-01-2008, 12:09 PM   #1356
GEO
GEO's Avatar
Send a message via MSN to GEO
Could you tell me..
What's the difference of CRC T-fource and Gen-x...?? What is better for an asphalt track...??
GEO is offline   Reply With Quote
Old 08-01-2008, 06:08 PM   #1357
The tfource is a tbar car with an associated dynamic strut front end. The genX is a side link car with CRC's unique prostrut front end. Both are really good cars that are fully capable of winning on most any surface. It comes down to personal preference and the talent of the driver....tbar vs side links. Tbars are a little easier to setup since they are somewhat simpler and also a little less adjustable. Lots of people like them for that simplicity. And others choose the side link cars because tbar breakage becomes a non-issue and the batterys are so easy to install with the rubber oring retainer system. I suggest you follow your own personal preference or else choose the car that's best supported in your area (either by your local hobby shop or by the local experienced racers there who are generally very happy to help you out with setup information). Either way, you can't go wrong. Both of the CRC cars are top notch offerings and they both have the racing pedigree to prove it.
vafactor is offline   Reply With Quote
Old 09-02-2008, 01:54 PM   #1358
Frank and CRC congratulations on the big Vegas win!
How long before we can get Hupo's setup?
Thanks.
TEAM MICHIGAN MAFIA
Resident of Detroit, "Where the weak are killed and eaten"
Jeremy Otis is offline   Reply With Quote
Old 09-02-2008, 02:14 PM   #1359
rpoage's Avatar
Yes I second that, Congratulations to Frank and CRC boys and girls on the big Vegas win!
rpoage is offline   Reply With Quote
Old 09-02-2008, 03:47 PM   #1360
smyka's Avatar
if you want hupos set up you will have to ask brian "dumper"wynn he wrenched on his car all week
TEAM CRC,TEAM TRINITY,JOHNS BSR RACING,JR-RACING/SPECTRUM,DYNAMITE/BLUE THUNDER RACE FUEL,parma/pse,chewy graphix,denys design,,novak electronics,rikter graphix
smyka is offline   Reply With Quote
Old 09-04-2008, 02:05 PM   #1361
Mark,
I think we would be interested in your 1/12 scale setup as well! Did you run the long ball and brace up front?
Brian,
Could you spread the knowledge as well?
We would all appreciate it!
TEAM MICHIGAN MAFIA
Old 09-04-2008, 08:48 PM   #1362
Thanks.
Thanks Jeremy and all, we appreciate the nice words.
Team CRC had a fantastic weekend in Las Vegas, winning 1:12th mod and qualifying 1-2 and 7. In addition, we were T.Q. in 1:12th stock as well with 5 cars in the A-final. The Gen-X 12 cars were very good and our small running changes to the cars have kept us on top and in the lead with regard to 1:12th technology.
In addition to the great performance of the cars, we have recently re-vamped the tire line with new compounds and better mounting and truing. In modified, the entire front row was CRC Pro-Cut tires, the original High Roller tire now copied by all the manufactures.
Regarding setup…. I wrenched Jilles second place mod car as well as my 3rd qualifying stock car;
Frank’s 2008 Vegas setup
Front –
** CRC Black fronts – 1.65” – 42 shore, glued outer sidewalls
** .50 mm front springs with very little pre-load
** -.5 degree camber
** Long ball upper arm with 5 degree dynamic caster blocks.
** 2 caster washers to the rear
** 3.5 mm ride height clearance
Mid –
** New Prototype CRC “Encore” shock – (new bladder micro shock coming from CRC)
** Red center spring
** .5 mm down travel (pod drooping when held in the air)
** Level chassis and pod at race weight (bottom plate and chassis in straight line when at race weight on smooth surface)
** Batteries Back
** 4 mm ride height
** CRC/Black Art Audi R8C body
Rear –
** New CRC exclusive short diff hub with the 3349 Brushless Pod conversion for perfect center motor placement.
(Remember racers… simple fact, if you don’t have a short hub, your pod is NOT balanced with a brushless motor. Standard length hubs make it impossible to center the weight on a brushless motor, it doesn’t matter which brand of wheel you use.
** 20000 weight in tubes
** White side springs with no preload.
** CRC’s new “Grey-low”” tires. These are mostly yellow compound with a ring of grey on the outside… hence “Grey-low” 1.70”
** 4.25 mm ride height
Qual 3rd, Finish 4th.
Jilles Groskamp Gen-X 12 2008 Vegas setup
Front –
** CRC Magenta fronts – 1.65” – 42 shore, glued outer sidewalls
** ..45mm front springs with very little pre-load
** -1 degree camber
** Full caster
** 2 shims on each front axle.
Mid –
** Copper center spring
** Batteries forward
** 4 mm ride height
Rear –
** Red side springs with no preload.
** CRC’s new “Yellow” tires. 1.70”
Qual 2nd, Finish 4th.
We will get Hupo's and Marks setup here asap!
Thanks again guys.... the cars, tires and drivers were looking good in Vegas. Trophy girls too! :-)
Team CRC is offline   Reply With Quote
Old 09-06-2008, 04:45 AM   #1363
Wow!
Now that's a detailed setup report!
Keep em coming! They really help us little guys.
Thanks Frank.
TEAM MICHIGAN MAFIA
Old 09-06-2008, 08:51 AM   #1364
Here is the setup that Hupo had on his car for the main:
Front -
** CRC Magenta front - 1.65" 35 shore glued inner and outer sidewall
** .50mm front springs with very little preload
** 2 caster shims to the back, 1 to the front
** 3.75mm front ride height
Mid-
** .5mm down travel in pod
** 3.5mm ride height
Rear-
** 30000 weight in tubes
** Red side springs with very little preload
** CRC Yellow rear tires 1.70"
** 3.5mm rear ride height
TQ and 1st in the A-main.
As you can tell, this setup is a little more "mellow" than the setup on Jilles' car. The motor in Hupo's car was almost a year old, so he was just a little down on horsepower compared to the newest generation of brushless motors that are available. So Hupo and I decided to give him a car he could drive hard, right from lap one. Looking back, I think 20000 in the tubes would have made him a little quicker through the corners, but he was happy, so I left it alone.
Any questions, feel free to ask.
Brian Wynn "dumper"
Team CRC
www.teamcrc.com, advanced electronics, www.teampowerpush.com, www.crcraceway.com, www.spektrumrc.com, www.dynamiterc.com, dumper's speedshop. moby graphics, G2 Designs - Check them out in the painting thread!
***2008 ROAR 1/12th Scale Stock National Champion*** Now what were the odds on that in Vegas? 38.4mm>38mm end of story.
dumper is offline   Reply With Quote
Old 09-06-2008, 09:46 AM   #1365
smyka's Avatar
smyka's set up
here is mine and its easy since i really dont change much hahaha im LAZY (just kidding)
front
.50 springs
1.5 camber
short camber ball
4.5 deg. caster
10 degree reactive
h brace to raise caster block had new crc alum. blocks
servo angles
mid
battery forward
crc new shock 35wt oil red spring raised .50 in front and rear
rear
new brushless pod
20000 in tubes
white side spring(only thing i changed usually run reds)
no preload
tires
new crc yellow rears mag fronts
my car was very easy to drive
alexander's car
same as mine but had 5 degree reactive and long ball with 1 degree camber
Forum Jump
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 05:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 05:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 05:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 03:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 03:22 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
