Can't get a clean cut with my Integy super lathe 3, any help?
#35
I just ask a machinist to fix my lathe, They know all the things that need to be adjusted and have the tools to make sure its right, and they can examine your bit and tell you if it needs to be sharpened or replaced. That will get you the best performance out of your lathe, and the performance will last a very very long time.
#37
Super Lathe 3 uses an AL-4 bit according to McMaster-Carr. Even though the Super Lathe 3 cuts towards the right, it uses a left hand bit because the bits are installed upside down from industry standard. This is the source of much confusion...
If you still don't believe me, just match your bit to the illustration on McMaster-Carr's "Single-Point Carbide-Tipped Tool Bits" reference page.
Style AL:
Stule AR:
Style AL:
Stule AR:
