Xray T2'007
#1082
Suspended
who cares what Paul was running. You are not going to be as good as him
#1083
Is that cheese wizz on your cracker or is it fromunda cheese...?
Even if he isn't as good as Paul maybe he wants to know what to run so he doesn't waste money buying the wrong gear....
-Shookie <><
#1085
Careful CheeseCRACKA!
Glover can sure wheel a car! I'm not saying he's Paul Matier but he's a great guy and a great driver! I also know that he represented Team Canada in the TCS onroad race in California as well.
#1089
Just got finished building my T2 "007". I have to say I've never had a car go togeather as easily as this one. I thought my FK05 was awesome, but this was 10x better! The only thing I didn't like was having to file down the battery slots so much to get 4200's to fit, but thats a problem in all cars so I guess I can't complain. Can't wait until it hits the track!
#1090
almost whole Xray team was runing dbl pink all around. about the tire width depend on driver it self i did saw some driver was using 28mm some using 26mm but i 100% sure that Paulie and his another team mate Ray Darroch was runing 26mm in mod and 19t. i have talk to Ray he told me you will get ton of steering when you using dbl pink all around compare to dbl pink org front but the traction compound you only can apply not more than 25% on the tire for starting apply if you still find not enough steering put more compound on the tire. i believe it depend on driver i also try dbl pink all around and i cannot get used to that setup and i found out the steering you get on the dbl pink all around is inconsistence maybe my hand glitching or what. after that i change back to normal combination.
#1091
#1094
US
EU
But no prices yet.... Anyone??
I hope the fact that they added so many unnecessary parts that the thing is not over priced:
Stuff that should not be needed to convert T2r and T2:
-spur gear
-springs
-wheel nuts
-suspension arms
-allum posts.
We will have to see, shock towers included instead of the 5 un needed parts, would have been nice for the T2r converters...
EU
-spur gear
-springs
-wheel nuts
-suspension arms
-allum posts.
#1095
I had another good showing with the car. Tested a few more things. Every change on this car does what it's suppose to do and you can feel it on the track. Next weekend will be more of the same. I tested on yhe rear end mostly with a few changes to the front. Next week will be mostly front end changes.
Fred H.- Are you running sway bars on your set up? I'm thinking of taking them off.
