Team Losi JRXS Type-R
Squarehead...I haven't hacked or dremmeled anything on my car but I do run the Flying Fox layshaft which creates a little more width for batteries and I know the following packs will fit:
Any Trackpower brick style pack with 4mm bullet plugs (the gold coloured ones)
The Checkpoint packs that were built by Trackpower (shiny red coloured ones)
Thunderpower 4200 mAh ProRace packs (TP4200-2SPR) w/ pigtails
I've had first-hand experience with all of these in my JRXS-R...HTH!
Cheers,
Mike
Cheers,
Mike
Out of curiosity, can anyone contribute to a list of ROAR-approved hard case LiPo packs that fit in this car without any modification? So far, the only luck I have had is with the original Orion Platinum 4800 20C. Anything else out there less than 47mm wide?
Hacking and Dremmeling of the car should not be a prerequisite to being able to use contemporary LiPo packs in the JRXS Type R.
Thanks Mike, I have been trying to find any of the FlyingFox parts for 5 months with no luck. I might have to source someone here in the US to manufacture a similar layshaft, because they don't seem to want to sell any more products.
Do those packs listed above fit without the FF layshaft?
I don't know what happened with Flying Fox...I ordered a second layshaft several months ago direct off the Flying Fox website and it arrived relatively quickly from Australia to Canada via airmail...don't know what's going on now though.
I can't say absolutely if they will fit w/o the layshaft as I've never run my Type R without it but I suspect they would, or possibly only require the thinning of the pulleys on the layshaft as outlined several times in this thread. If I get a chance tonight I'll measure things up and let you know if they'd fit with the stock layshaft.
Cheers,
Mike
Cheers,
Mike
Just trim your stock pulleys and shim the stock layshaft, no reason to go find a super special battery.
ps... Doug thanks for the loan of the lower shock retainer at the Nats. Much appreciated! Can't believe that part fell off!
Good to know, guys, thanks.
Paul, when you run a JRXS-R, you always have to be your own parts supply store.
Guys,
Any news on the Losi new touring car?Please share.
I know Losi is busy with the 22 off road buggy.
Hope the new design not going to do lots of modification to fit Lipo and limited type of motor and can accept standard spur.
Cheers
James
Cheers
James
I haven't heard any noise about a new TC.
So maybe I'm missing something (and admittedly, I haven't caught up to the ~13,000-odd posts here), but after spacing out the top layshaft as far as it can go without creating binding in the system, and sanding down the inside of both pulleys flat and smooth, and there really isn't the kind of extra space generated that some of you guys have mentioned. With the pin placement in the stock layshaft, there really isn't any more distance you can generate with spacers.
What am I missing?
Also, what is the increased distance in the pulleys with the FlyingFox layshaft?
What am I missing?
Check out post #12709 for a mod that can be done to the layshaft assembly using Losi parts to obtain adaquate clearance between the pulleys to use any battery. Your next potential problems would be battery length, battery height or battery tray size. Bottom line is that Lipo manufacturers did a big disservice (in my opinion) to the sport when they released batteries that would not fit some of the older cars (HPI Pro 3 and Losi JRXS-R to mention a few).
Calvin, how did you go about making sure the spur is centered on the new hub? I used a PRS spur gear adapter as a template for the new gear holes, and the spur is not concentric, unfortunately. I guess my tapped holes weren't perfect on the drill press and the gear wasn't centered. Gonna have to find another solution or another Orion Platinum LiPo.
What am I missing?
What am I missing?
I didn't do any kind of spacing just simply shaved down both parts of the two part pulleys so when you put them together the pulley would be narrower. Thereby creating more space for the battery. Haven't measured how much it gained but would guess you could probably gain close to 3mm of extra room depending on how much you shave off.
Ahhhhhh... now that makes a lot of sense. I'm going to have to try that next.
