Tamiya TB Evolution V
#1891
Hi, does anyone make a hard case lipo 5000 mah or higher with the bumps on the bottom, I bought one of these kits and wanted a lipo to fit the regular chassis, if some one can point me in the correct direction thanks
#1893
Prior to buying OVA's EVO 5 MS I starting to buy parts to build one. I happened to have the TBO3 rear prop shaft, TB03 Spur gear holder, and Non-MS motor mount. So I took my car apart to test some stuff out and to show some pictures of the differences.
The good news is that it did fit! See pictures below. (I didn't shim them perfect but close enough for testing.) The only thing that is off is that it does move the spur gear closer to the motor mount so the hole cut out in the bottom of the EXO chassis is not lined up anymore. This really isn't an issue because the biggest spur gear that will fit is a 84 tooth (64p.) There is still clearance under the spur gear as seen in picture 2.
I have the MS (picture 3) and Standard motor mounts (picture 2) shown.
#1894
For sale: half completed exotek conversion project
Lost interest in project.
8/10 TB evo v roller.
New in pack Exotek lipo conversion kit.
New in pack TB-03 aluminum universal propeller shaft.
New in pack carbon reinforced short reversible suspension arms x2 packs.
Used Trinity D3 17.5T sensored brushless motor.
Package price: USD 350
Please send me a PM if you are interested.
#1895
#1896
I am happy that went so fast because I was looking in my sofa for more R/C money.
#1897
First Race with My Exotek Evo5 !
Hy there!
Raced my Evo5 Exotek for the first time last Weekend, and i have to say it was a pleasure to drive!
I practiced only 3 Packs on Saturday and it was dailed in from the first Practice Pack to the last final run!
Managed from 4th in the grid 3rd overal in a competitive filed. Thx to Mike for the superb conversion work.
Greetings Rainer
Greetings Rainer
#1898
Are you using split blocks? Or just the normal blocks for the FR and RF blocks
#1899
I used the normal 1 pice al around. The car have so much flex, so i think its not neccesary.
I also have installed the center post, and runed geardiffs F and R. Front Ride gum, and rear 2k oil.
Greetings Rainer
#1900
[QUOTE=Travis S;12238228]I assume this was using the standard EVO 5 spur gear holder and not the TB03 holder like I tried in the photos. The TB03 holder moves the spur much more to the front then the EVO 5 holder would.
The TB03 part would've also worked. I just wanted to keep everything blue. You have to turn the spur gear adaptor on opposite from the instructions
#1904
#1905
From what I have read so far, the 502 diff assembly is shorter then the tb evo 5, so the whole diff would fit would just have to shim it correctly, has anyone tried this mod, using the entire 502 diff, versus just the gear and ball and using all the tb evolution parts thanks
