CK25AR 1/12th car kit from Team CRC
#91
CRC 25 AR
MY car weighed 722g with liteweight AMR body with 42mm tires, all steel screws before rewiring and setup
#93
Anyone know of good videos explaining how to build a free front end, square rear pod, and proper way to set the axle height on CRC CK25s? I have a way that I found works, but seeing how others do things always helps.
#94
Front end I use mothers polish on the kingpins, pillow balls and suspension pins. Makes for a free setup and takea maybe a minute or two per part.
#95
#96
Does anyone have a rubber tire setup they could share?
#97
#98
Thanks.
#100
Am i really the only person that's having issues with the rear hubs? Mine is now slipping on the spool which I thought would happen🤬
#101
mine clamp just fine. Dumb question, but are you tightening both clamping screws equally? The hubs will spin on the axle if only one of the screws are tight. Also, it might help to tighten the clamping screws before fitting the wheels. And the last suggestion….the axle needs to be dry (no bearing oil) in order to give the hubs their best chance of not slipping.
#102
I'll try and make sure of the latter when I get back to the track today. But after swapping axles and hubs from another car it was still slipping last night
#104
It's been all the new double clamps that have done it to me including the one in the new kit. I have this one tight 'enough' for the last qualifier and if it slips ill put on the last new hub that I have but I'm going yo have to contact CRC on this because I've never had an issue with them before with any of their parts
