Team Associated RC10B64 Thread
#2746
#2749
can someone suggest pinion and timing for a Reedy 6.5 M3? Thanks
#2751
I have just placed an order for an RC10B64. I will be running this on high grip carpet. Are there essential upgrades for this kit on carpet? Or is there a good setup I can use? I will likely be running a 13.5t with it. I do have an 8.5t I can run as well, but I find that to be a bit too much power on the tracks I run.
Thanks!
Thanks!
#2752
Front pills
Hi guys is there a pill chart for the front of the b64 anywhere thanks
#2753
Would anyone run this Chassis?
https://www.amainhobbies.com/psm-2.5...m01870/p695829
#2754
Thanks!
Thanks!
#2755
R/C Tech Elite Member
Thanks!
Thanks!
#2756
The vegas setup is a good place to start. The only other thing I would add in the beginning is the alloy rack. Plastic diff gears work fine for 13.5 so long as you have some slip tuned into the sliper. Crank it down tight or run an eliminator and you will kill plastic gears quick. If your planning on going back and forth between a 8.5 and 13.5 stay with the metal gears.
Thanks,
#2757
What batteries are guys running with the b64d?
#2759
#2760
storm800,you must be good on the track to put timing on 5.5t lol
