Xray XB2 2WD Buggy Thread
#4696
hopefully the XB2 is next on exotek's list, i have this on my B6 B6 FLITE TOP SHAFT, for flite spur mount #1726 - Exotek Racing
something like this would allow shocks on a XB2 DE to moved forward option for spec racing. of course it would be nice on CE too
#4697
That would be could, no need for a shaft sticking out to the body if your not using the slipper.
#4699
which washers are everyone using to fix this problem?
#4700
i think alot of people have had this on all of the hinge pins. ive seen some use washers or e-clips behind the screws to cover the pins. im worried about this on my xt2. i havent ran into anyone that had this problem with the truck yet but the screw heads just barely cover the pins.
#961025
#4702
Stock screws work fine.
#4703
R/C Tech Elite Member
wow, that must have been a serious hit. hard or med plastic parts?
in my various offroad crashes (very bad) with a XB2 DE near 1 year old, has been run weekly, and have broke nothing to date on it. i converted that same XB2 (one of three Xray cars i own) to race dirt oval latemodel class, it continues to go thru some serious crashes with no breaks that intended for oval only cars would not survive.
There was a small PVC pipe sitting on the outside line of the sweeper but on the inside of the track, came through the sweeper a full speed and hit it dead center on the front of my buggy. Just a real solid "thud" when it hit, I knew something had to be broken but it still drove so I finished the final lap. I did however finish and win that heat.
Only other thing I broke on this car in the year+ that I've owned it is a rear arm.
#4704
for the hinge pin issue...these have slightly bigger heads than the ones xray supplies https://www.amainhobbies.com/protek-...h-3100/p141759
perhaps the washers or updated screws with make it to 2018 XB2
#4705
#4706
#4708
All I have left to do is mount some tires, solder ESC and motor before I get to feel it out, but I'm clueless about one thing because this is the first kit, of the three I have, that didn't include a place to mount the RX antenna. Where and how are you guys mounting or securing your antenna?
#4709
now xray may have done a silent change on newer kits? the above poster who was having issues may have a older car/kit? maybe some newer kits have the larger heads than when the XB2 was first released
#4710
