Team Associated SC5M Thread >
Like Tree84Likes
    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Old 06-02-2015, 06:38 PM
  #46
Originally Posted by Jmuck69
Look at the pics on the AE website, white front and rear.
Aw dang. 3.6"lb fronts 2.1"lb rears. What them white fronts rated at
Keith B is offline
Old 06-02-2015, 09:16 PM
  #47
kbish76's Avatar
Does anyone know if the o-rings are the x-factory? Or the usual red ones. And will the Hi-Flow body fit this new SC?
kbish76 is offline
Old 06-03-2015, 01:06 AM
  #48
ScottKelly911's Avatar
I'm assuming you meant X-rings not X-factory But no, it'll come with the "new improved" red o-rings just like the other 5 series vehicles from AE. But most people will still use the Kyosho red x-rings anyway because they're better. And yes, the Hi Flow body will fit as the size is nearly identical and only slightly different than the SC10.2 They're not reinventing the wheel here, infact speaking of wheels, it still uses the first gen SC10RS KMC wheels, so hopefully you wont need to go to the +3's and they engineered it to work without the +3's and simply utilize the stock wheels better than previous gens did by using a wider hex to push the wheels out further to the outside of the axle.
I can't wait!!! I really hope this gives SC a boost and shot in the arm around here because I love SC! I also hope that this gives PL and JC a reason to start coming out with some new SC bodies, because the SC body selection has gotten kind of stale as of late and remained essentially the same for over a year.
Edited because I gave wrong info, kit will not come with x-rings
Last edited by ScottKelly911; 06-03-2015 at 03:52 PM. Reason: Correcting wrong info
ScottKelly911 is offline
Old 06-03-2015, 04:31 AM
  #49
does this mean it's possible to use +4.5 wheels with different hex's on this truck ?
slowsrc is offline
Old 06-03-2015, 05:03 AM
  #50
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
You would need a much thinner hex (4.5mm thinner) and probably a spacer for the nut. The threads on the axle won't extend far enough back to the chassis to allow the nut to thread on far enough. You could do that with the current line of trucks.
bds81175 is offline
Old 06-03-2015, 08:17 AM
  #51
Thanks for the info...so what you're saying is plan on investing in wheels and tires
slowsrc is offline
Old 06-03-2015, 08:36 AM
  #52
This truck looks great! I hope it will bring SC Racing back as Pro2 is pretty much dead down here at SDRC.
rbk1115 is offline
Old 06-03-2015, 10:39 AM
  #53
ridered4life250's Avatar
Its possible though. This is awesome because that means you can run HPi rims, which are mother-freaking awesome!!
ridered4life250 is offline
Old 06-03-2015, 01:46 PM
  #54
Tmc1's Avatar
Hope they come out with a factory team kit soon after the original release!
Tmc1 is offline
Old 06-03-2015, 02:05 PM
  #55
Trader Rating: 12 (93%+)
It is a team kit according to their web site,is that different the a FT kit ? Never mind I see the different team parts
Scottysspeedsho is offline
Old 06-03-2015, 02:57 PM
  #56
Going still decrease the flow in increments of 2.5 whenever that means
Keith B is offline
Old 06-03-2015, 05:13 PM
  #57
Blitz hex's are 4.7mm ?
slowsrc is offline
Old 06-03-2015, 07:10 PM
  #58
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
Really doubt thats gonna happen for quite some time!
Not really necessary though! The 5 series cars and truck is amazing out of the box!
thecman26 is offline
Old 06-04-2015, 12:51 AM
  #59
Cridd's Avatar
Trader Rating: 16 (100%+)
Kashima Shocks, titanium buckles and FT rear hubs would be the only upgrades I can think of.
Cridd is offline
Old 06-04-2015, 07:05 AM
  #60
kashima coating huh? someone rides motocross....
