Tekno RC SCT410.3 Thread
#4997
[QUOTE=Cain;14941496]last few times I have done this I have used jb weld. If the oil pushes past that we got bigger problems
I have heard of people using toothpicks broken off into the holes and then glue or something similar to seal it up.[/QUOTE
JB weld worked perfectly, thanks!
#4999
It will have an effect, negative or positive really depends on what kickup angle and camber link position you're running as well as your driving style.
Also I'm assuming you mean the washers that sit in between the ball stud and the spindle and the ball stud and the ackermann plate, not the ones between the ball stud and the head of the screws.
#5000
What do the ones between the screw head do? Are they not part of the bump steer equation?
Also can someone explain diff fluid. As in is it better to go lower or higher cst if your breaking traction easily?
Like trying to get on the gas out of a corner and the rear is breaking loose would a lower or higher CST benefit
#5001
Here's a resource that helped me understand diffs in the past.
http://www.myrcbox.com/articles/tech-article-diff-tuning-guide-for-buggy-and-truggy/
#5002
If the rear wants to pass the front at when you get on the gas a thinner center diff will help, but be aware you can go too light on the center diff and won't have any forward drive.
#5003
The angle of the link compared to the ground is the bump steer, the more the link is angled inwards (steering rack end lower than the outside end) the more bump steer you will have and vice versa.
I have 7-7-3 in the diffs now
#5004
i feel like some of you got the wrong idea about what different diff fluid are doing. Heavier diff fluid in the rear acts more like a locker. Thus laying more equal power down from side to side. This would make the rear end drive harder overall and would give more push. This makes the vehicle have a snap ability on power that would cause the rearend to whip around with aggressive throttle input and accelerate quicker down the straights. If power however will suffer through turns and or make it more difficult to stabilize on lose tracks. If you go light, it will handle easier and rotate better off power. But you will lose acceleration on the straights out over jump faces out of a turn.
The front acts similar in the way heavy will pull harder around turns on power, but will push off power and vice versa for lighter fluid. The center diff has more to do with power distribution to the front and rear. If you're to light, the front tires will balloon. To heavy and the rear will out drive the front on acceleration and make it hard top drive on loser tracks. for turning, you should really consider rear toe adjustment. The less toe in you have the broader the slip angel becomes, thus the better it will rotate. Turning has always had more to do with the rearend slip angles than it does with the front contrary to what most think.
#5006
Tech Legend
Alright so we managed to get a heat and a main in and it was quite fun. Track conditions were black dirt that when wet was like glue. It was so sticky that it bound up my drivetrain towards the end of the heat and had to be pried off.
I'll post more info later, but right now I need a bit more consistent rear end during turns as sometimes I would get the rear end ot break free a bit unpredictably and need a bit more low speed rotation.
#5007
Edit: wrong thread. Sorry!
#5008
Mods
Is there a company that makes a nice battery strap/hold down that is not Velcro? I have a 2s setup and would love to ditch the stock setup, for maybe a carbon fiber type setup like the 1/10 buggies. Thanks!
#5009
Trader Rating: 53 (100%+)
My SCT410 (first gen) that I had, I used the carbon fiber battery strap, posts, and thumb nuts for. Losi SCTE. I had to drill/countersink for the front post an it worked great.
#5010
Tech Legend
Alright got a bit of time here after ribfest. Didn't go race today so hope to do that next week.
Here is are some pics of the track and conditions, first pic is what was a bit overwatered:
This is how it was run saturday and I think how it will be going forward:
As I mentioned, the biggest issue I experienced outside of the packing of dirt into the drive shafts was not enough rotation but then a slight inconsistently of the rear end on power trying to step out.
Outside of that, vehicle was great.
