    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree70Likes
Old 08-03-2015, 08:14 AM   #1801
lala4fire's Avatar
Originally Posted by szymanski2oo1 View Post
hi all...... have just got my tekno sct 410.3 running and its great, i'm looking for setup help for running it on astro in the uk, have been looking on all the forums but cant seem to find anything..... any help appreciated.....
it had its first run in the sun on bumpy astro last sunday and it was grip rolling like crazy.
with the kit springs i cant get the drive shafts level the shock collars are fully wound up.
running almost stock setup at moment with below changes
diffs 7-10-3
shocks.. 350cst front 300 rear kit springs
shumacher yellow mini spikes all round
ps...sorry i posted this in the wrong thread a little earlier but im hoping this is the right one
http://www.teknorc.com/tekno5/wp-con..._Nationals.png
Try running lutz setup. It should help
Associated FT SC10.2 SCB/ tekin rs/gen2 10.5
Associated B6/ tekin rs 2/gen3 8.5 B5 rear motor
Tekno EB48.4/tekin rx8 2/gen2 1900kv
Tekno NB48.4/ Alpha Dragon III
HB D413/tekin rsx/gen3 6.5
lala4fire is offline   Reply With Quote
Old 08-03-2015, 08:16 AM   #1802
Dan.J's Avatar
Trader Rating: 21 (100%+)
Originally Posted by qstorm777 View Post
I'm running bladder shocks and green springs and I can get the stock ride heights. I would go thru the check list Matthew laid out. I'm hoping that fixes it. If not, maybe Tekno will help you out to get this fixed.
I do have a touch of rebound in the shocks and I'm sure I can get a few more turns on the shock ends so maybe that's all I need, we will see. Thanks
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 08-03-2015, 08:28 AM   #1803
Misfit138's Avatar
Trader Rating: 107 (100%+)
Would this be a good motor for my SCT410.3. 4000kv.
Misfit138 is offline   Reply With Quote
Old 08-03-2015, 10:34 AM   #1804
JAE
Trader Rating: 26 (100%+)
Spring change from stock green front/black rear to avoid nosediving? Not looking for perfection, but have read spring changes can help dramatically. thx
JAE
JAE is offline   Reply With Quote
Old 08-03-2015, 05:26 PM   #1805
I ended up putting AE 35wt oil in the rear shocks and changed nothing else and the nose diving is reduced DRAMATICALLY... i also find just swapping to a little thicker oil hasn't killed my handling in the really loose stuff my track is famous for. I'm afraid a stiffer spring will screw up my handling, but I bet that would help as well, but for now, I feel 100% better in the jumps.
Tekno EB48.3, EB48SL, and SCT410.3
Team Associated B5M Lite
HoldDaMayo is offline   Reply With Quote
Old 08-03-2015, 05:56 PM   #1806
DEADWright's Avatar
For me, the rear springs were too long to get the ride height where I wanted it, and was having nose down,endo issues. The fix was yellow FRONT springs and 40w for the rear shocks, stock set up in the front.
Tekno SCT410,EB48.3,ET48.3
DEADWright is offline   Reply With Quote
Old 08-03-2015, 11:44 PM   #1807
JAE
Helpful gentlemen at Tekno support was adamant the 410.3 stock setup was ideal to minimize nosediving. He mentioned the problem people have is with the build. Told me to lower the droop and go up 5 oil weight... sounds simple. hope it works.
JAE
Old 08-04-2015, 01:39 AM   #1808
FAO
FAO's Avatar
Location: Germany near famous clay track of RCRT Duisburg
diffs 7-10-3
Did You cut your tires pins? At least 2 lines of the outside of the front tires and 1 line outside in the back. For very high grip track we use additional tire glue at the outer side of the front tires. So the car could slip sidewas, if it is rolling up.
The former seastar:
Tekno SC 410.3, Serpent Spyder SCT, dust, loomy, slippery, dirt
FAO is offline   Reply With Quote
Old 08-04-2015, 01:47 AM   #1809
FAO
FAO's Avatar
Default Lightweigth .3
Solved the nose down problem with small motor can (450 size, -100g, light controller in the back left , -60g and shorty lipo-100g. Car is about 2650g without body. The first race (Clay, getting dry and dusty) was much better than the others before, but need more practice. Next test will be on astro turf.
The former seastar:
Old 08-04-2015, 02:27 AM   #1810
Anyone tried the 4 x 1.8 flat pistons from the eb48.3, just ordered some and I am going to follow the eb48.3 setup .my sct410.3.stock one is horrible.i liked my sct410 way better than the new one.tried all kinds of pistons and springs, oil, position , bladder, emulsion, vented, if thar pistons dont work , I'm selling my tekno .3.
Snarf450r is offline   Reply With Quote
Old 08-04-2015, 04:43 AM   #1811
Default pins
yep cut two rows off the front and one off the back..... i did move thr front shocks out 2 holes which helped but wasnt a perfect fix!
szymanski2oo1 is offline   Reply With Quote
Old 08-04-2015, 05:41 AM   #1812
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
What exactly is wrong with it? In reality, the new truck is not a ton different from the old truck with included hop ups and improved suspension geometry. Let us know what you think is wrong and we should be able to help. Don't throw your money away. It's still the best 4x4 short course truck on the market by a long shot.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 08-04-2015, 08:30 AM   #1813
FAO
FAO's Avatar
Did You tried to reduce suspension travel by using the droop screws?
The former seastar:
Old 08-04-2015, 09:30 AM   #1814
What is the main difference between using the 6x1.5 pistons vs 10x1.2 pistons? How much droop should I person drop down for running on high bite carpet?
Showtime90 is offline   Reply With Quote
Old 08-04-2015, 10:39 AM   #1815
Originally Posted by Aswild View Post
Yea same issuie but trying to work it out, i went with pinks all @ ,, i did want to no if any ones rear dog bones are rubing on the bottom of the arms right by the hubs ?
Nobody notice the rear dogs rubing
Aswild is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
