TLR 22SCT 2.0 Race Kit: 1/10 2WD SCT thread
#61
Are they releasing a support kit for this?
^^ and good question on the sway kit
#62
OK, I will be running my 2.0 indoor carpet. I will be converting it to MM and I am looking at the following upgrades out of the gate.
TLR338001 MM conversion kit
[TLR234006] Team Losi Racing 22 2.0 Caster Block Set
[TLR2936] Team Losi Racing Aluminum Front Hex Set
[TLR1049] Team Losi Racing 25° Brass Kick Angle Shim (TLR 22)
[TLR1072] Team Losi Racing Aluminum Front Pivot (TLR 22)
TLR2062 Team Losi Racing Aluminum Front Camber Block
[TLR1550] Team Losi Racing Aluminum Servo Mount Set
[TLR2061] Team Losi Racing Aluminum Mid Motor Rear Camber Block
TLR334002 Team Losi Racing Rear Sway Bar Kit
TLR334001 Team Losi Racing Front Sway Bar Kit
[LOSA2954] Losi Complete Gear Differential Set (22RTR)
I was reviewing the manual on the TLR website and comparing the part numbers to the original 1.0 and I figure the above hop-ups should work (if a TLR guy can confirm it would be great )
Looking at ordering these as spares:
TLR234030 Front Arm Set: 22SCT 2.0
TLR234031 Rear Arm Set: 22SCT 2.0
TLR234029 Front Spindle Set for Bell Cranks: 22/2.0/SCT
TLR234033 Rear Hub Carrier (2): 22SCT 2.0
If there are any others I should consider please let me know
#63
22sct 2.0
Hello.
I am planning on picking up a 22sct 2.0 when is comes out.
My question is: with the new shocks, will the LF spring kits fit this model
or will a new set be released?
I would love to us some parts from my 22 buggy but not sure they will cross over.
Tom
Tom
#64
TLRacing
Frank,
I just binged watched all of your preview videos on YouTube. They definitely belong on the OP. Have you done any testing with the 22sct 2.0 on a dusty, loamy outdoor track? Will the aluminum rear camber or low roll center toe plate from 22sct 1.0 fit on the 2.0? Is there a sway bar kit available ?
Yes, the same LF springs for the rear will work. These will not be a new set released. Many parts cross over, but I'd recommend to cross reference the two manuals (22 2.0 and 22SCT 2.0) for specifics.
#65
Frank Is it still looking like a late October ship date?
#68
Hello,
I want to know more about Team Losi Racing 22 SCT 2WD.
1. Is this car easy to drive for asphalt on road racing ? In my country, on-road short course racing is becoming more popular. Racers usually piloting 4wd team losi scte and tekno racing 4wd. I want to use 22 SCT 2WD for simplicity reason. Am I going to be disappointed chosing 2WD truck ?
2. As part of on-road SC racing regulations in here ..... Racers are required to use 1/8 On Road GT Tires. Usually they use Sweep Racing tires. Therefore , 17mm Hex Adapter must be use for aforementioned tires. Is this fit ? MIP 17mm Hex Adapter Kit, Traxxas Slash 2wd #10114.
3. Do u have any suspension setup suggestions for asphalt racing ? Should I use middle or rear motor mount location ? I prefer to have stable rear end rather than fish tailing rear end.
Thank you for enlightening me.
#71
Hello,
#73
