Like Tree28Likes
Old 01-13-2015, 10:00 AM   #7036
ProfessorX's Avatar
Trader Rating: 17 (100%+)
Originally Posted by RENOV8R View Post
Great, I'll take some photos tonight.
Testing 1,2
Nice clean set up 👍👍👍👍
ProfessorX is offline   Reply With Quote
Old 01-13-2015, 10:36 AM   #7037
Trader Rating: 52 (100%+)
guys that are running the rcshox's pistons what springs and oil are you running?
Mugen MBX7R
Mugen MBX7R Eco
Losi 5ive
CarFanatic is offline   Reply With Quote
Old 01-13-2015, 10:42 AM   #7038
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Which RCshox pistons? single or dual stage?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-13-2015, 10:50 AM   #7039
RENOV8R's Avatar
Originally Posted by ProfessorX View Post
Nice clean set up ��������
Thanks. I'm kanda picky that way. Never know if it's going to end up on a shelf LOL
RENOV8R is offline   Reply With Quote
Old 01-13-2015, 10:51 AM   #7040
slakr's Avatar
Trader Rating: 28 (100%+)
Front: Losi 35wt/2-hole 1.6/HB Red
Rear: Losi 30wt/2-hole 1.7/HB Gold
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 01-13-2015, 11:39 AM   #7041
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
Does anyone run the speedo behind the motor? I was considering this mainly just because of cleanliness of running the wires, so it's not a big deal. But since Ty runs it in front of the motor, I didn't want to throw the setups way off by moving the weight around. Any thoughts on if moving the speedo to that location would have a big impact on how the setups perform?
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 01-13-2015, 12:03 PM   #7042
2-1.6
Mugen MBX7R
Mugen MBX7R Eco
Losi 5ive
Old 01-13-2015, 03:10 PM   #7043
Trader Rating: 519 (100%+)
Yeah, my Son and I both do, mostly for a little better balance and the fact that this car has plenty of steering, at least for our track..I started our cars with the reedy set-up (mostly) but have been dialing out steering since then..
flame56mx is offline   Reply With Quote
Old 01-13-2015, 05:00 PM   #7044
Trader Rating: 120 (100%+)
I have 2 buggys, one with the esc in the front and one in the rear. There is not a big difference in the handling. It's really just a matter of preference.
22-4
MBX7R Eco, RC8B3E
MBX7R. RC8B3
JoeC is offline   Reply With Quote
Old 01-13-2015, 05:22 PM   #7045
Has anyone found an alternative aluminum servo horn?
It appears the hex on the stock servo saver stripped out while I was setting EPA (yeah I know!!!)
Has anyone tried running a standard servo horn and put the ball stud facing the front of the car?
phillypete is offline   Reply With Quote
Old 01-13-2015, 05:53 PM   #7046
Don't know if this has been posted before, but for those of you who are cheap like me and don't want to fork out the $ for an upgraded steering rack, here's what I did: Grabbed a couple standard 4X8X3 bearings I had kickin' around. Drilled out the bushing holes in the rack to accept the bearings. Slipped the bearings in with a .5 mm spacer on top and bolted it back together. Result is just about zero steering slop.
I did a nearly similar thing with ours, used a flanged bearing top/bottom..
Hot Bodies D413 1/10 4WD Buggy-d413-steer.jpg
Here is what's on mine. I know the other ballstud is doing nothing, but it's an offset for weight, lol.. Not sure if I would recommend this with a shorty servo though..
Hot Bodies D413 1/10 4WD Buggy-d413-servo.jpg
Old 01-13-2015, 05:55 PM   #7047
is there a certain way these r/c shox pistons go on? one side is flat other side has in dent.
DIRT DIGGER is offline   Reply With Quote
Old 01-13-2015, 06:03 PM   #7048
slakr's Avatar
Flat side up
Old 01-13-2015, 09:50 PM   #7049
Flode007's Avatar
Send a message via MSN to Flode007
The TLR 22 alu servo horn
Flode007 is offline   Reply With Quote
Old 01-14-2015, 06:19 AM   #7050
ISH
ISH's Avatar
TLR1557 servo horn.
ISH is offline   Reply With Quote
