    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 05-24-2015, 06:39 PM   #1471
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Teufel Racing View Post
Try:
http://www.petitrc.com/setup/kyosho/...0816/setup.pdf
Or:
http://www.petitrc.com/setup/kyosho/...2125/setup.pdf
Or:
http://www.petitrc.com/setup/kyosho/...2125/start.jpg
Those should be of help.
One of my friends really likes Kevin's setup. I'm pretty close to that with a couple little changes and gear diffs. Seems to work pretty well for me
Thanks...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 05-24-2015, 06:47 PM   #1472
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
I tried a new rear end this weekend and I really liked it. I didn't feel like I lost any steering but the rear end felt pretty solid. I always felt like the rear end was a little stiff with the wider pivot and really like how my RB6 is with the narrow rear end. I will get a setup posted tonight.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 05-24-2015, 07:50 PM   #1473
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
What, another hot setup up?
I'm going to have to check that guy out.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 05-24-2015, 09:40 PM   #1474
K_King's Avatar
Here you go
Our track has clay and misters, but it can get anywhere from wet, to dry, to dusty to gripped out and I found this handled all of those pretty well.
Old 05-30-2015, 04:11 PM   #1475
I used the Bezerk carbon top deck this weekend and made the buggy more stable and took away all the edginess in the buggy. Still had plenty of rear grip, just made the buggy easier to drive hard. Ran on outdoor track, can't wait to try it indoors.
potatobed409 is offline   Reply With Quote
Old 05-31-2015, 05:21 PM   #1476
I've had a 22-4, Cat K1 Aero and now the ZX6. I'm blown away. What a nice car. I will say that the belt cars feel more efficient, but this thing is so stable. I'm able to just drive. So fun.
scoobyrs25 is offline   Reply With Quote
Old 06-01-2015, 06:43 AM   #1477
Anyone testing the new rear arms (UM713B) and how does it work compare standard? Someone testing it on a bumby track??
Also the LAW46 lightweight outdrives. How does it work? Advantges?
Ses88 is offline   Reply With Quote
Old 06-07-2015, 09:09 PM   #1478
MayorRC's Avatar
Anyone have a starting point for 13.5 blinky gearing?
Kyle-Keenan.com | MayorRC.com | McKune Design | Hella Graphics | 2WDMod.com | Kyosho | Orion
MayorRC is offline   Reply With Quote
Old 06-08-2015, 10:29 AM   #1479
I'm running 28/78 but a buddy can't get that to fit. He is running ?/76. I'm sure he will pop up soon on here. Just watch you temps.
Jeremy Clark
RB6 for Mid, ZX6 and an untold number of Axial crawlers for family fun...
Arcain41 is offline   Reply With Quote
Old 06-15-2015, 06:48 AM   #1480
didrace's Avatar
Hi there,
I am having problems with my ball diff.
I have build and run the car for one race and the rear ball diff ring gear was damaged.
IS it because i tighten the screw too much?
Is there someone that could give me some advice on the building of the ball diff?
What lube is good to use? Which one are you guys using?
I need some advice
didrace is offline   Reply With Quote
Old 06-15-2015, 09:22 AM   #1481
I'm at 26/76 for the most part, have used 27/76 as well. Both of those for bigger tracks. Ran a 25/76 for a short track. Fan on motor, usually set for a 10min +4 laps and will be around 150-157 temp wise with the stock body.
Using a LRP fan mount to move the fan more forward on the motor to clear the body.
Jerm,
You should have my gearing memorized by now as we've talked about it enough times. Lol.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Old 06-15-2015, 09:49 AM   #1482
Hello everyone,
This is my first post.
I am from Singapore.
May i know, where can i buy the 3rd party made upper chassis ?
foosoomin is offline   Reply With Quote
Old 06-15-2015, 08:32 PM   #1483
Originally Posted by foosoomin View Post
Hello everyone,
Hey foosoomin
Look out for Bezerk RC on Facebook. Great guys down in Australia.
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 06-16-2015, 01:46 AM   #1484
didrace's Avatar
Originally Posted by didrace View Post
Hi there,
I need some advice
anyone?
Old 06-16-2015, 02:46 AM   #1485
anyone?
Nope - likely to have been the pinion for the diff is not shimmed closely enough to the diff gear and also your slipper was probably set to tightly. The slipper is there to protect your gear train.
ST - Losi 22T 2.0
