TLR TEN-SCTE 2.0 Kit Thread
#8626
I just purchased a used roller from a buddy at my local track because i know TLR will be coming out with a 3.0 or something new in the near future, I can feel it So like we all would do, I'm going to strip it down and replace all worn out parts, but i also want to upgrade what should be upgraded. What i have so far is:
LOSB3569 Losi Differential Gear Set w/Hardware (Ten-T)
MIP12199 MIP TEN-SCTE Mod1 Spur Gear (41T)
MIP13249 MIP Pro4-Mance SCTE 2.0 Rigid Chassis Brace Kit
PTK-6701-RSZZ ProTek RC 12x18x4mm Dual Sealed
PTK-MR105-2RS ProTek RC 5x10x4mm Rubber Sealed Bearing
PTK-MR126-2RS ProTek RC 6x12x4mm Rubber Sealed Bearing
TKR2212 Tekno RC M6 Front & Rear Outdrive Set
TKR2213 Tekno RC HD Center Driveshaft (SCTE - Front/SCTE 2.0 - Rear)
TKR2217 Tekno RC HD Center Driveshaft (SCTE - Rear/SCTE 2.0 - Front)
TLR3100 Team Losi Racing Aluminum Rear Gearbox Bearing Insert Set
TLR332001 Team Losi Racing HD Differential Housing w/Integrated Insert
TLR334017 Team Losi Racing Aluminum 15 Degree Front Spindle Carrier
XRA964050 XRAY 5x15x0.3mm Washer
What else do you think I need?
The washers are a good replacement part and also kyosho small pins i believe 9.8 mm x 2mm diameter for the axles and behind the hexes. Also, bearings for the whole car.
#8627
#8628
There are no 5x10 bearings on this rig. You need 5x11 for diff pinion. The MIP spacer between the pinion bearings does make them last longer. MIP 5x7x 2mm Bearing Spacers (2) #10127 This is one area that ceramic 5x11 bearings help keep maintenance down and prevent diff problems. If built right the diffs can go 100-200 lipos between cleaning/replacing out drives. http://www.rctech.net/forum/electric...letproof+Diffs
Save your money on the rear drive shafts, use stock here. The big benefit is up front for more steering angle and less wear. Keep in mind the Tekno M6 stub axle tends to bind when used with aluminum hubs on the rear. Funny, they fit the stock plastic hubs perfectly. We covered that a couple of times in the Pro8 thread.
If you race on large tracks, the metal chassis stiffeners are great. Who wants to deal with plastic rod ends that need replacing after one nose plant, short on the triple
The front top plate by KHZ is overlooked by most people because they don't understand how it helps. It does two things. It prevents the two screws at the front of the steering plate from pulling out of the diff housing or bulkhead. It also ties the front end together by bolting through the shock tower, gear box housing to a metal top plate over the steering that adds rigidity all the way back through the chassis stiffener to the chassis. Its one of those parts you don't think you need until you install it. http://www.amain.com/rc-cars/king-he...te-010/p268743
KHZ center diff support/motor mount is nice, but not absolutely necessary. I find the bearings are often binding after a couple of race days on loamy outdoor tracks and it needs cleaning often to keep friction down. It does help out drive wobble, but 2.0 mounts hold up well and the new diff case last a year easy even with a little wobble. The Xray diff washers also cut down on the wobble. Spend that cash on the ball bearing akerman plate by Vision Racing and some rod ends that last more than a few runs before they slop out. I'm not a fan of sloppy rod ends.
I'll stop there. This platform is well supported by aftermarket and been around long enough to have parts support beyond most all other serious race rigs. There is room for improvement, but it runs near the front of the pack out of the box.
I personally hope they have a 3.0 in the works with steel balls in the rod ends, ball bearing akerman plate, Xray diff washers, Tekno shafts all around and down the center, larger bearings for diffs and inner stub axle. A newer shock design like the TLR 22 rig would be a huge upgrade on 3.0 and selling point. A flat plate or flat chassis location for ESC would be nice as well.
#8629
Anyone know what the output shaft is for a spektrum S6040 servo, how many teeth are on it
#8631
Thanks is that the same as a futaba
#8633
so who else is 23T JR?
#8634
#8636
