Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 01-30-2014, 06:46 AM
  #9601
R/C Tech Elite Member
Trevor Williams's Avatar
Trader Rating: 207 (100%+)
I run 33/72 with a Schuur Speed motor....32° endbell timing.
Trevor Williams is offline
Old 01-30-2014, 06:54 AM
  #9602
Holmberg418's Avatar
Originally Posted by MikeXray
That's still very high on gearing for a 17.5, most run 30-33/69.
+1 with the d3.5 with a Ht rotor, an max timing I always ended up with 31-69. That always felt the best for overall power on the bottom and top end.
Holmberg418 is offline
Old 01-30-2014, 06:57 AM
  #9603
1967rs's Avatar
Trader Rating: 56 (100%+)
I run 35/69 with 17.5 Killshot HT rotor and stator 40deg on the endbell, motor temp about 110deg
1967rs is offline
Old 01-30-2014, 06:59 AM
  #9604
Moderator
Posvar's Avatar
Trader Rating: 470 (100%+)
^^^^ At 35/69 Are you running the STRC motor plate in order to have it fit? I know that gives you one more tooth or so over the stock plate. Mine is at 33/69 and temps are 95-100 so I am adding a tooth.
Posvar is offline
Old 01-30-2014, 07:03 AM
  #9605
kenny lutz's Avatar
Trader Rating: 38 (100%+)
32/66 on mine that was when it was 1560g now it's 1499 I might be able to go 33
kenny lutz is offline
  #9606
whitrzac's Avatar
Trader Rating: 97 (100%+)
You can run 35-69 on the stock kyosho plate, but not any more than that...
whitrzac is offline
Old 01-30-2014, 07:11 AM
  #9607
I need to try a 69t this Saturday.
Old 01-30-2014, 07:12 AM
  #9608
Moderator
Posvar's Avatar
Cool. I tried that but it made me uncomfortable if there was any movement at all. It was TIGHT!
Matt
Posvar is offline
Old 01-30-2014, 07:59 AM
  #9609
Man, the LW Blade body is like paper! Gonna spray bomb it solid white amd hit the track tomorrow, hoping to get some good runs in...my car got a fresh B-fast diff, new Savox 1251 lo-pro servo and Kyosho LW body.....between the body and servo I shaved 32g off my car.
Old 01-30-2014, 09:44 AM
  #9610
VenturaDC's Avatar
Trader Rating: 32 (100%+)
I did forget to mention Im running the broad range rotor, my buddy is geared 32\69 on a tekin Gen 2 and I can out motor him basically everywhere on our track. I'm sure with a different motor id be geared more similar to the standard
VenturaDC is offline
Old 01-30-2014, 09:48 AM
  #9611
gelshocker's Avatar
Anyone running mod with lightweight chassis, or just for stock? Thx
gelshocker is offline
Old 01-30-2014, 01:12 PM
  #9612
1967rs's Avatar
Stock motor plate, rear motor.
1967rs is offline
Old 01-30-2014, 04:18 PM
  #9613
nickdawg18's Avatar
Trader Rating: 33 (100%+)
Thought smac was closed this Saturday?
nickdawg18 is offline
Old 01-30-2014, 04:50 PM
  #9614
Gayosaka's Avatar
Mr Tebo put his Reedy Race setup on his blog. Interesting stuff
http://jtprc.com/2014/01/30/rb6-reedy-race-setup/
Gayosaka is offline
Old 01-30-2014, 05:11 PM
  #9615
mog ruith's Avatar
Originally Posted by VenturaDC
Yes please do let us know, I had bad luck with my 5yo sons sct ready set shocks, which I've upgraded. Now he is really wanting a bugI y so was thinking the ready set rb6 but absolutely did not want to have to buy another set of big bores right away.
I had a few laps yesterday, out of the box it handles well. Made some adjustments on the rear shocks and it drives much better. Cleared a tabletop twice till i managed to broke the rear hub. Are the hubs on the pro kit and rtr the same? Same material? And just an update the shocks are still holding well.
mog ruith is offline
