Kyosho Ultima RB6 & RB6.6 Car Thread
#7711
His lap times with the mid motor that week were pretty much the same as his lap times rear motor. You have to understand though, Fred has ALWAYS preferred mid motor cars, even when others didn't. He ran mid motor almost all the time at bumps with his Durango (people just never asked cause he was slow :P).
As far as will MM work for us at bumps? Really depends on what Chris does with the dirt. If it's tacky, yes, it should work fine. If the grip is down, then you are going to lack forward bite when you try to get on power out of all those tight turns. I know I'll be running RM unless the grip gets super high. Even then I'm not sure I'll switch. I'm just building a whole second rear end so I can if I choose too.
#7712
Well I see there is a Mmr hanger for the rear. But which one do I use for the front position? Just a regular old rf hanger I presume?
#7713
For the RF hanger I believe you can use they new one that allows narrow or wide. http://www.speedtechhobbies.com/inde...roduct_id=5789
#7714
Trader Rating: 89 (100%+)
rear hangers
hanger with mid-motor configuration? Advanced Thanks!
#7717
If you run the old style narrow rf it will work but you will lose motor gear ratio adjustment(you can shave a little of the block), should be ok but for most ratios. Other wise umw705 runs mid and rear, narrow and wide. The only rf part you will ever need.
For the rear you need the new rr hanger umw707 let's you run wide or narrow in mid. Or exotec make one to.
#7720
For the rear you will need either the new Kyosho hangers or the Exotec ones if they make a narrow version (I dont know if they do).
Also the Kyosho ones are basically 3+ versions in 1 with a ton of options. All you do is change inserts.
Theres 7 different widths you can get from the inserts with the standard 3 toe.
Kit calls for 3.0 and Out-Bs, which I believe is the standard RF2, so in-B should be RF1. From there we can actually go up to out-D, which should really free the rear end up, or in-D which should lock it up a lot. I am going to try in-C on both would I think is a tick narrower than RF1s.
#7721
For the front you want to use RF1. RF2 is what the manual calls for as the stock rear hanger for mid is RR2.
#7722
mid-motor
Are you mid-motor drivers adding any weight to the chassis if so, where and how much?
#7724
#7725
I dont run any weight in mine in mm. But im running on carpet
