Kyosho Ultima RB6 & RB6.6 Car Thread
#4067
Ok i pulled the trigger and bought the RB6 with all the other parts listed on here. I run on a tight clay track with medium bite. What set up should i start with? I have seen alot of different set ups on here. What should i start with?
#4070
the Kit setup.. trust me.. i started with the zero caster inserts and put AKA cc inserts upfront. Dialed.
#4072
You built something wrong. The motor should be able to slide all the way forward. Does it slide all the way up if the motor screws are taken all the way out? There shouldn't be anything for the motor to hit inside the motor guard.
Take the motor out, and take a picture of the hole/motor guard area where the motor would sit.
#4074
That's the mid motor rr2 block. The holes are clearance holes for the screw to pass thru to the mid motor bulkhead. I can't believe the screws didn't fall out.
#4076
Yep, that is the RR suspension hanger for the mid motor setup. Break out the other 4 (two pairs of two) and line up the narrow pair, and the wide pair, and run one of those pairs (wide for more steering, narrow for less). The piece you have mounted there, toss in your MM pile of parts.
#4077
Thanks for all the help, If anybody has the plastic susp. holders from the build for rear motor and have not used them, let me know i may be interested.
When I bought the buggy he did not include the other MM parts or in this case proper RM parts
#4079
I have to admit the more I run the car the more I am impressed. I have been playing with pistons and oils and have settled on a setup for my current layout that seems very easy to drive fast in mod. I did also switch to all Orion gear and all I can say is its so smooth it's deceiving. I sort of wish more of the K drivers would pop in and share info on what the team has discovered works or doesn't work. Would go a long way in helping us all develop.
