RC10B4/T4 Forum
#7501
R/C Tech Elite Member
I think you are all crazy. TRF makes the best shocks in the world.
PS. I never have shocks that leak because I actually work on my cars every race day. Also you need to clean your car after every run. 5 min of cleaning will make anything last a lot longer and will cost you less.
#7502
Rear- Long shock body that comes with the RB5 and the new long shock shaft
Front- New short rear shock body with the shaft that comes with the RB5
#7503
thanks to ae shocks i have to work on my car every race now also cause they always leak..
#7508
I am goin go do it this weekend i think since i am not runnng my RB5. This should work i think
Let me know what works. I heard silver rr w/ 54mm shaft on rr, and velvet rr in front unsure on shaft length.
44mm body 48mm shaft in frt?
#7509
#7511
#7512
Rear - Mid arm RB5 velvet bodies, 54mm shaft, 1 mm downtravel limter.
Front - Std RB5 fronts, .5 mm uptravel limter.
Go 2B piston front and 2C piston rear with 30w rear and 25w front to start.
That is the setup that I ran on the lightweight lipo setup and it worked very well.
The std body rear RB5 bodies are too long from what I found.
They're the best, haven't you heard?? Must be the way they're being built....
#7514
This is something ev1 who drives ae should see
There is a great article on building shocks at http://users.telenet.be/elvo/12/8/1.html. Shock bodies aren't normally the problem; the problem is with the spacers.
