Like Tree23Likes
Old 02-19-2012, 08:59 AM   #4486
CHIZZLE's Avatar
Trader Rating: 37 (100%+)
Originally Posted by stavman View Post
So.....
Got my front end rotating GREAT......
Becouse the front is softer and rotates.. Not Pushing... my Rear is pretty loose...
Any Thoughts Guys???
Stav
Shorty or stick pack? Middle, front, rear? Any weight? I'm running a shorty pack in the middle, with 2 ounces of weight right behind the servo. I'm diggin' it but looking forward to getting my hands on some softer front springs.
Chance Renstrom
Repeat after me......"toy cars"
CHIZZLE is offline   Reply With Quote
Old 02-19-2012, 09:11 AM   #4487
stavman's Avatar
Reallly... hmmm
Short up front and 2 ounces of weight on servo...
Ill try moving both and see how it works.....
Mike Barnes... Mr OCD himself... got his dialed with no push and hooked mine up..... He has softer springs from Billy F so his rear is a BIT more Planted...... May change some oil as well... Dont have any different Pistons...
Gunna do some PRIVATE test and Tune today... If I can get my Tired ASS up.... Been a LONGGGGG 3 days of racing at the New Shop... FUN but Tired
FYAIDGASAM
stavman is offline   Reply With Quote
Old 02-19-2012, 09:15 AM   #4488
Teambcw's Avatar
Trader Rating: 28 (100%+)
can anyone give me a starting point for the sc10 gear diff oil? I will be running indoor clay med-high bite. Thank you
OCRC / C$ race setups ...... And my Wife
Teambcw is offline   Reply With Quote
Old 02-19-2012, 09:53 AM   #4489
spiro's Avatar
Finishing my build, and filled my shocks today. Now, would anyone care to guess which problem I ran into?
Yep. O-rings are squishing out underneath the cap. Current solution: screw the cap on loose enough to not get the problem, but I'm worried it'll unscrew itself as it's really too loose.
I remember reading something about this earlier, but can't find the posts. I'm leaning towards trying to dremel the inside edge of the cap to create a cone edge, but stopped before going there because I can't see Durango designing this good a ride with the need to dremel down new parts. Pretty please - tell me what the mounting trick is, as I've never had this problem with the AE shocks. (Unless I forgot the bleeder screw in during tight-down.)
[ DEX210 ]|[ DEX410 ]||[ Futaba 4PK ]
spiro is offline   Reply With Quote
Old 02-19-2012, 09:57 AM   #4490
KyoshoShawn's Avatar
Brandon Collins, ive tryed to look closer to your steering rack shimming and mods and I cant see close enough to what you have done to eliminate bump steer. Can You break it down for me. And did flipping the steering rack help?
Zx5 FS2 SP NCG Edition. R10 Powered. Rt5
Rb5SP2. Orion & Castle Creations ESC's
Ultima SC-R. Orion & Novac motors
MP9Tki2WC. MP9e. Orion & Savox servos. Kal-Gard Lubricants
Team Terribles Byron Fuel OS Speed engines
KyoshoShawn is offline   Reply With Quote
Old 02-19-2012, 11:03 AM   #4491
Furtado66's Avatar
I am running AE 1000 diff oil with the SC10 diff. You can also try 2000
Furtado66 is offline   Reply With Quote
Old 02-19-2012, 11:04 AM   #4492
Furtado66's Avatar
Put some shock oil on the o-ring. That will solve the problem
Old 02-19-2012, 12:34 PM   #4493
RacerMike42's Avatar
Thumbs up
Another thing you can do (what I did) take an exacto knife and chamfer the inside edge of the shock cap. It doesn't take much and solved the problem for me.
AE SC10 4x4
AE SC10
Durango DEX210
OFNA Hyper 9e
RacerMike42 is offline   Reply With Quote
Old 02-19-2012, 12:49 PM   #4494
CHIZZLE's Avatar
Reallly... hmmm
Short up front and 2 ounces of weight on servo...<--This is what you have?
Mike Barnes... Mr OCD himself... got his dialed with no push and hooked mine up..... He has softer springs from Billy F so his rear is a BIT more Planted...... May change some oil as well... Dont have any different Pistons...I want to get those spring sets because I want to try softer up front and harder in the back. The kit springs are more set up for MM if you ask me.
Chance Renstrom
Old 02-19-2012, 12:56 PM   #4495
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Sounds like you built them incorrectly. The initial black disk that goes in first needs to be put in correctly, or the entire group sits out too far. Happened to me the first time too... didn't seem right... looked everything over again really closly and found the problem. Built correctly, the shocks go together like clockwork.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 02-19-2012, 12:58 PM   #4496
Trader Rating: 49 (100%+)
I would agree with you for the ProLine part, but i don't see JC doing anything real soon. Aren't they slightly chained to AE?
Most think JC is tied to AE, but they do have drivers for other makes, i.e. Durango's Billy Fischer and TLR's Dustin Evans. And they did release a Finnisher body for the Durango DEX210. So give it time and I think JC would release a wheel for the Durango.
iadevil is offline   Reply With Quote
Old 02-19-2012, 12:59 PM   #4497
Super Moderator
hhmm.. im not sure I can explain it much better than I did on my post with the photos. I put the ackerman plate on the bottom side of the pivot arms instead of on top... then used small non-locking nuts and a 1mm shim (i think) for the inner ballstuds.... If left alone, the steering rack will now hit the arms... so to fix that, I shimmed the ENTIRE assmebly up. I did that by putting large shims underneither the two pivot arms, bringing the entire thing back up a tad. Shim it little by little until you get the steering rack to clear the arms.
And yes, it will allow you to get rid of all your bumpsteer. Instead of running 7 or 8mm of bumpsteer spacers (which cant really be done)... you can now run 2 or 3.
- RCSpecialties -
Old 02-19-2012, 01:09 PM   #4498
stavman's Avatar
Big Difference....
Ran as is... 2oz on my Servo and Shorty up front.... was better than yesterday.... figured so i was TOAST after the 3 days racing....LOL
Moved Shorty to about Middle...... BIG Difference..... With the changes Mike did I dont need the added weight up Front...... Gunna try with Battery all way back and see how that feels....
Was pretty tired so i called it a day....
Time ta grill some DEAD COW in the 70deg sunshine......
Thanks Chance.... sometimes the simple things will work....
Ill SCREAM if the shocks come available this week..... i have a BUNCH of singles as well... so ill see what is available 1st.....
Stav
FYAIDGASAM
Old 02-19-2012, 03:00 PM   #4499
Teambcw's Avatar
has anyone tried the kyosho diff rings as a temp until durango gets them back out. I dont have any kyosho stuff laying around and was told it would work.
Old 02-19-2012, 03:30 PM   #4500
jmackani's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Autocratic View Post
After talking to one of the Hobbico reps at Motorama, they probably won't be doing anything to change the way TD operates for awhile, if ever.
Reason why, is TD still has a standing contract with HRP on being the sole distributor in the US. Also, TD has to get off their ass and start getting more parts made and in larger quantities. From what I've seen over the last two months, HRP hasn't been doing that bad on getting things out.
Bottom line is, if they don't have the parts, they can't distribute them.
Not sure I can believe this. The price on the DNX408 has dropped drastically and all the speculation is so HRP can dump what they have in stock in less than a month. They have not touched the other cars which are mostly out of stock anyway. As a matter of fact, the HRP distributor website shows every Durango vehicle out of stock.
LCRC Raceway http://www.lostcreekcycles.com/lcrc.htm
Proline Racing http:://www.prolineracing.com
jmackani is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 Today 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
