Durango DEX210 Thread
#4501
Not sure I can believe this. The price on the DNX408 has dropped drastically and all the speculation is so HRP can dump what they have in stock in less than a month. They have not touched the other cars which are mostly out of stock anyway. As a matter of fact, the HRP distributor website shows every Durango vehicle out of stock.
They seemed hopeful about the Hobbico purchase, but said that Durango still needs to be sending them the stuff that is wanted by the public. If you look at TD's website, alot of the stuff is out of stock, so even if you wanted to spend the money on shipping, there's nothing to buy.
In my opinion, even after talking to both Hobbico and HRP, I think it's too early to tell at this point what's really going to happen.
#4502
Thanks guys! Comments:
I'll try that, but I think someone wrote earlier that they got this problem when they spilled oil on the o-ring during filling.
That's what I was planning with a dremel. I'll try this as well.
That's a great tip Captain, or should I say it would be - if my problem was the bottom of the shock, not the top. Thanks anyway!
Sounds like you built them incorrectly. The initial black disk that goes in first needs to be put in correctly, or the entire group sits out too far. Happened to me the first time too... didn't seem right... looked everything over again really closly and found the problem. Built correctly, the shocks go together like clockwork.
#4503
take the bleeder screw out when putting the cap on. after a few times this stops, wanted to throw my 410 shocks against the wall after 10 times of this happening.
#4504
#4505
anybody has the 210 geardiff in stock ?
Im ready to buy one.
#4506
http://www.rctech.net/forum/r-c-item...-shorties.html
someone told me to post that over here since alot of 210 guys are looking for shorties hah.
#4510
Moderator
Trader Rating: 470 (100%+)
ASC9827
HPIZ892 (2 packs)
The diff drops right in and I was told to use 10 shims on each side
I also ordered Associated Silicone Fluid in 1000 and 2000.
#4513
I had the same problem with the cap O-ring grabbing the cap too. I put some shock oil on it and it didn't really help, so I just tightened the cap down really slowly and carefully to the point where there was a decent amount of torque on it and left it. There is no way to get it tightened down so that the cap meets the body without creating more space for the O-ring. So far the caps haven't leaked at all and I don't think that they will. The issue is just that it's a weird design with the O-ring being sandwiched between two flat surfaces. TD should have added groove in the cap.
#4514
hi guys,
i m new to 2wd and i m planning to buy a dex210..
i ve just a couple of questions:
-do you think this electronic would be fine: lrp sxx stock spec, 10.5 gm motor,
servo sanwa 801??
-which pinions should i drive with the 10.5 (timing and no-timing)??
does it change anything in the ratio by changing the number of gears or the motor position??
-lastly, how is it to drive a 2wd buggy? is it fun? compared with the 4wd??
easier to maintain??
thanks so much to every one can help me..
thanks!!
servo sanwa 801??
thanks!!
#4515
