novak motor plug
novak motor plug
hi the plug on my novak brushless motor melted and i need another one
is there anywhere i can get one as id rather not have to buy a new motor,
its the plug with 6 wires coming into it that plugs into the speedy
Novak sells them , http://www.shopatron.com/product/part_number=5356/135.0
You will have to cut one plug and solder the wires to the motor . If you are good at soldering it is no big deal .
No, you may be able to solder a section in to it , but to me its not worth
it for fear of frying your speedo next. You need to send it back to Novak I
think the replacment cost is $50 for a new motor.You also can buy a motor
with a replaceable sensor such as a speed passion motor.
Dynodan22
Dynodan22
im not to bad at soldering so ill give it a go,
and dynodan22 how would doing this risk my next speedy, if there all soldered good i cant see it being a problem?
