JConcepts Thread
#5971
I will look into it later today; our team drivers including Brent Thielke & Maifiled have been running the new arms on their trucks for several races with our wheels and hexes. I also have one in my office using the new arms and no clearance issues; but we are of course using the JC hexes . I will check the stock T4.2 hex and wheel for a different offset.
#5972
We actually have them in stock, but they haven't made the official press release and not on the website yet; maybe today or tomorrow. I believe they are already shipping to distributors .
Well that's a first. The majority of the time product releases are made and then the public does not see the items for up to 3 months.
#5973
Pressure points in stock here, along with the SC wheel dishes. http://www.superiorhobbies.com/istar...page=30&pos=60
#5974
I have a question that hopefully someone could answer. I just bought a set of Hazzard SC wheels and the new Hazzard Dish covers for my TLR 22SCT. I noticed on the wheels, they have small pin sized holes in the rims around the where the bead sits (not the two venting holes). Are these tiny holes so you can put a tiny dab of glue on the backside of the tire bead or are they to allow dirt to escape if it gets into the sidewall of the tire? I don't really have a problem with tires coming unglued, but I suppose a little extra dab of glue around the entire circumference of the tire couldn't hurt and i only run indoor on clay so I don't have a problem with dirt getting inside of my tires. Just curious about these tiny pin hole sized holes as I've never seen them on other wheels before. Thanks!
#5975
#5978
#5980
closed cell inserts
hi, questions on closed cell inserts for 2whl buggy,
indoors low grip at 50-60 deg temp, would close cell still be preferred in rear or standard foams???
thanks
thanks
#5981
I've actually had some tires where the closed cell insert has broken down and doesn't feel like it should work, but on low-bite conditions the tire works awesome
#5982
thanks, if the temps were higher like above 70 deg would you recommend them then??? or are closed not good in low bite????
#5983
