What happened to tire glueing lately?? >
Like Tree18Likes
Old 08-03-2019, 09:39 AM
  #31
Trader Rating: 14 (100%+)
Originally Posted by Juglenaut
All I do to dismount a tire is with low boiling water for 15 min. Boil new tires in water with about 5ml of dish detergent. Sand, scape, and prep old wheels and low boil in detergent water. Let everything dry for 15 minutes. Mount and glue.
I have never had a tire fly off, some small peels but never lost a tire.
Again all super glues, hobby or otherwise reacts with water absorbed into the rubber and plastic which are slightly hygroscopic.
Giving this a a try and have some 1/10 wheels boiling for about 30 min so far and they are still prerty solid?
ctrenks is offline
Old 08-03-2019, 09:48 AM
  #32
Well they kinds came off but the foams are toast i think as they got real thin I think ill stick with acetone vapors
ctrenks is offline
Old 08-03-2019, 10:49 AM
  #33
Trader Rating: 19 (100%+)
I don’t boil the foam inserts.
Checking all my tires and I can not get the bead to release without ripping to rubber. So I am not sure what all the mysterious problems vs no problems​​​​​​.
Are you letting them sit for half a day after super glueing?
Juglenaut is offline
Old 08-03-2019, 01:02 PM
  #34
So how do you dismount tiures by boiling them without the foam in them? Some serious magic going on there in my head I bought some new pro line glue so going to clean up and re-try my troubled ones again soon
vintage1 likes this.
ctrenks is offline
Old 08-03-2019, 03:44 PM
  #35
I do have to get new inserts most of the time. By the time I have to dismount the old tires the inserts are bad. Most new tires come with inserts.
Old 08-03-2019, 03:50 PM
  #36
Ahh I was dismounting to keep the tires not the wheels so much
ctrenks is offline
Old 08-04-2019, 01:35 PM
  #37
morgoth's Avatar
Cut the tire open with a pair of scissors first. I use a pair of lexan scissors and I start in the vent hole of the tire. Then I can take the foams of the wheel and boil the remaining rubber of rims. This allows me to reuse foams. And used foams are usually better.
Cain and Juglenaut like this.
morgoth is offline
Old 08-07-2019, 09:07 PM
  #38
I’ve found Simple Green works well. I believe it works better than a solvent as it removes less moisture from tire, encouraging cure as CA cures with moisture. I didn’t see how long you let’s tires cure before running; how long after glue were tires ran?
Hands001 is offline
Old 08-08-2019, 09:53 AM
  #39
DaveW's Avatar
Green 3M abrasive pad to scuff the rim mounting surface. Dremel and a sanding drum to scuff the tire mounting surface. Clean both with denatured alcohol (cheap and effective) and clean terry towels. Allow to dry. Mount tires. Crack open a new bottle of your fave CA. Apply to the front side of all tires, using bands to secure, then go back to the first one and do the backside.
Done.
Treat your CA like milk. Buy only what youll need, or the rest goes to waste.
mushroomed likes this.
DaveW is offline
Old 08-09-2019, 07:24 AM
  #40
I think it was some bad CA, I did buy 2 bottles from amazon asnd think those were them (AKA Premium) who knows how old or how they were stored, I bought some Proline and all seems back to normal now
ctrenks is offline
Old 10-19-2019, 01:15 PM
  #41
OK, someone told me to try harbor freight super glue, its about $3 for a 10 pack. So far its seriously the best ive used, only issue is that it comes out fast but even fixing older tires its just real good
ctrenks is offline
