Hitec 625 MG
Hitec 625 MG
Me and a bunch of friends are having problams with this servo not wanting to center back up and it hang's in one place alot any thuoghts
What type of setup is it being used in? What other equipment are you using in the vehicle?
1-10 scale nitro trucks used for stearing radio is a jr xs3
If you are using an inadequate power supply to power the servo with such as alkaline batteries I have seen this happen. You want to use a good rechargeable battery 4.8-6.0 volts when using high torque servos. Also if the receiver you are using has a BEC circuit in its battery port you will want to bypass it.
Bypass
This may sound like a silly question but how do you bypass the BEC? I am having the same trouble with my 5625mg?
The BEC circuits are only in the battery channel. To bypass it plug the battery into an open channel or use a "Y" harness to connect the battery and servo into one channel (your steering or throttle channel.)
servo
Thanks I will try that.
