Trackside
Old 09-06-2012, 11:37 AM
  #16201
Waltrip55's Avatar
Originally Posted by AaronR
January 1st is a Tuesday, so maybe that could be a daytime race instead of the regular Tuesday night program.
Thanks for the heads up, maybe I should have looked at a 2013 calendar.
Waltrip55 is offline
Old 09-06-2012, 02:06 PM
  #16202
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Originally Posted by celt
and thanks for the schooling...
Yeah right, I just got lucky.
Kraig is offline
Old 09-06-2012, 02:50 PM
  #16203
Davidka's Avatar
Trader Rating: 86 (100%+)
Originally Posted by jbrooks39
I was told JConcepts Blue Compound Bar Codes were the tires of choice for THR. Is this (still) correct? I am guessing the Green compound will just wear a bit quicker?
Thanks,
JB
I have found the Losi Pink Bk-Bar (rear) and Taper-Pin (front) to be the best most of the time for 2wd buggy though I haven't raced since winter. They are much better when the track is moist and at least as good when dry imo. Wear with the pink rubber is also great. Use closed cell inserts in the rear or the foam will break down long before the tire is done.
Davidka is offline
Old 09-06-2012, 05:22 PM
  #16204
microbomb's Avatar
Yes, the pink bk bars still work best when the track is still moist but later on in the night Blue barcodes V2 work better when a groove starts to form and it dries out a little. Its best to keep a set of both on hand.
microbomb is offline
Old 09-06-2012, 08:11 PM
  #16205
lilws6's Avatar
3d's worked all day today from wet to dryer they seemed to get better thru the day may just be the tires coming in but i liked them alot. I've also liked my proline holeshots. I like pin tires i guess
lilws6 is offline
Old 09-11-2012, 05:21 AM
  #16206
jsinclair's Avatar
Is there open practice this Sunday the 16th ?
jsinclair is offline
Old 09-11-2012, 06:54 AM
  #16207
Gas Rat Racin's Avatar
Trader Rating: 37 (100%+)
Is there racing this Friday? Is there any other points series than the Saturday fever one?
Gas Rat Racin is offline
Old 09-11-2012, 09:15 AM
  #16208
BuckMan's Avatar
As far as I know...yes!
We run a 10 week point series for our Tuesday and Friday night club racing as well. These are separate from each other as well as the Saturday fever series.
BuckMan is offline
Old 09-11-2012, 09:45 AM
  #16209
When do they start/stop? What are the rules? Are there drops?
Old 09-12-2012, 08:59 PM
  #16210
jsinclair's Avatar
Thanks,
Do I need to bring anything, table chairs ect....
Old 09-13-2012, 05:15 AM
  #16211
kevntri's Avatar
Thanks,
just your driving skill
kevntri is offline
Old 09-13-2012, 05:17 AM
  #16212
celt's Avatar
Thanks,
Nope...
Trackside has awesome pit space. Indirect down-lighting with upper shelf storage. And I've never run out of the supplied power strips either.
All that's requested is that you use a pit towel/mat and a lipo sack for charging lipo's if you use them.
celt is offline
Old 09-13-2012, 05:43 AM
  #16213
Trader Rating: 17 (100%+)
Can you feel a difference on the track between bar codes V1 and V2? I want to order some tires up for the spektrum race, but not sure if V1 is better or V2 works better.
Thanks.
Chico is offline
Old 09-13-2012, 06:13 AM
  #16214
storm800's Avatar
Trader Rating: 23 (100%+)
Yes you can feel a difference, best bet would be to order or buy a set of each.
storm800 is offline
Old 09-13-2012, 02:26 PM
  #16215
Is there much of a mod 2wd sc class on Tuesday nights?
