Go Back  R/C Tech Forums > General Forums > Vintage Forum
Gearing question for early 2000s Trinity motor. >
Like Tree1Likes
  • 1 Post By mild seven
Rate Thread
Old 03-23-2023 | 09:18 PM
Default Gearing question for early 2000s Trinity motor.
I just finished getting an old TA05 that my cousin gave me up and running (the car hasn't been used since '08).
I'm a complete noob to most RC stuff so I just wanna make sure that the gearing combo I have installed right now won't risk overheating or killing the motor.
See below for the part specs.
  • Motor: Trinity Cobalt Pro Tweaked (Part# TRI2002)
    • RPM: 19,178@ 5.0v
    • 27T Brushed
  • Gears:
    • Spur: 70T
    • Pinion: 22T
  • Battery:
    • 7.2v 3600MaH 6-cell NiHM
  • ESC:
    • Tamiya TEU-101BK
Secondary question, anyone have recommendations for cheap brushless ESC and motor. Thinking about changing out the old electronics when I have the chance so I can use some 3s LiPOs I got kicking around.
CraigKn is offline
Old 03-23-2023 | 11:34 PM
mild seven's Avatar
with that motor you probably want to gear at around 6.2. you will be safe with what you have. (from memory the internal ratio is 2.25)
CraigKn likes this.
mild seven is offline
Old 03-25-2023 | 07:03 PM
Agreed. Good place to start.
Denver_Larry is offline
