Fullthrottle Motorsports
#4126
Originally Posted by dodgeguy
Bill what were you doing up so early? Or have you not been to bed?
and sleep is not in my book right now..... with the big car sale at work
i have to find the time for fullthrottle man are we taking off or what
and order are going out to day
#4129
Originally Posted by heathl
Hey Steve W, what's a good brush-spring setup for the co27 in a 12th scale on a tight carpet track? thanks
#4133
glitches
cbfreak, also make sure u put servo tape under the wire for the speedo as it passes thru the batt channel, then put another on top to insulate from batt, that sometimes will cause it too, and try to route antannae wire through a hole made into antannae tube about 1 inch above chassis instead of wiring it thru chassis, have had to do that before too , that way antannae wire does not touch chassis anywhere, hope this helps.
#4134
Guys,
Thanks for the suggestions so far... I'll work on it some more tonight when I get home from work. If you have any more thoughts, don't hesitate to post 'em up. I don't want to miss racing on Friday because of this!
#4135
guys i want to welcome STEVE EAVES to the teamfullthrottle gang
also we got more KD 19t s in and more brushes in so let steve or i know
what you need .we are leveing to go racing this weekend so the last order's are going out thursday
bill D.
bill D.
