TQ Wire
TQ Wire
Questions about TQ Wire products, comments, product suggestions? Post them here.
I've been getting a few call about this....
When you use the TP "charger specific" balance extension cable (#2203) on the new TP820CD make sure the connector on the cable is shifted to the left side of the charger's balance port. The cable was designed to fit the TP610C that has a shorter port.
In fact, the standard TP balance extension cable (#2201) will work in either of the above chargers if shifted to the left side of the charger's balance port as well. However, unlike the #2203 (which has both TP and XH battery connectors) this standard cable has only one connector for the battery - for TP only.
Here's some eye candy c/o Mike Haynes...using TQ Wire products.
That charger looks so cool!
Trader Rating: 51 (100%+)
Gotta give Ralph TQ wire props, been running his stuff for quite some time top quality stuff and a great guy as well!!!
I have added a 85mm flatwire sensor cable to the line:
The "Fairtrace" was designed for TC's using an LRP speedo with the sensor port positioned to the center of the car. In this instance the 70mm was too short and the 100mm too long.
http://www.tqwire.com/sensor.htm
New triple black servo extension for rewiring jobs.....only one end and slightly less expensive.
http://www.tqwire.com/servocable.htm
Rev7
So, I was looking at the different varieties of wire on the site... What is the HD in the HD 5 wire kit on the 16 ga. wire page?
