EAMotorsports discussion thread
#2147
Gentalmen patience! we will have Mr. EA at the event. I will be picking Mister Anderson up and delivering him to the track!
I have threaten to kill his livestock of sheep if he doesnt comply!!!!
Hey Eric why do you have sheep?
Oh wait! Insert cuello rojo joke here!
#2148
Team EAM
Re: EA 19t C2
Originally posted by elusive-drfiter
how should i gear a 19t C2 motor tuned by the man himself EA..
noticed that the RPM and torque is not significantly more than a EA monster stock ... actually sometimes it's less ..
For stock i run 24/26 tooth pinion to a 76tooth spur.
Tried running the 19t the other day on a high grip large flowing track and i was gearing it with a 32/35 tooth pinion. But still was not sure if it was right ...
I drive a 415 with foams on outdoor asphalt tracks ..
pls advise thanx ...
The 19 turn is dynoed at different amp loads than the stocks are. Thats the reason in RPM difference. Are you running foam tires or rubber tires?
EA
#2149
#2150
Re: EA 19t C2
How long is the track ( front or back straight), is it technical, and what are typical lap times?
#2151
Re: Re: EA 19t C2
We need to know the size of tires if your running foam. Since your running foams start somewhere around a Final drive ratio of 5.80. keep an eye on the color of the comm!
I race on foam tires with a dia of 61mm ... final drive was best at 5.09 ... straight is prob 40m long ...
narrow sweepers in the mid field ...
best times was 14 laps 5.08
#2153
speedxl, please tell what the color of the comm indicates. I've noticed that sometimes the comm turns an orange color and sometimes it stays shiny copper color. Does the color indicate heat due to under-gearing or something else? Thanks in advance.
#2154
comm/wires color
BLACK: buy a new motor.
DARK BROWN: toasted (same with the wires) beyond way over geared. smoking! there goes that motor.
Brown: getting to "toasted" WAY over geared.
Orange: over geared a tad.. better gear down.
Copper: gearing is just right.
oh ya..EA..toasted a C19 last saturday. car was fast. after my run.... smelled like i was BBQing some ribs or something.
#2155
#2156
Guess we have to make arrangements for the team boss to get picked up at the Airport.
#2158
I fly in from Japan on the 23rd to LAX.... if He's coming in to LA I have him covered but if it"s San Diego.... He will have to use the "FOOT MOBILE"
-Dave
#2159
LAX........ Late Wednesday night.
Jeff
Jeff
