Fukuyama Batteries
#5836
no problems~
you may have to play around with the peak setting, depends on the pack's temp. if too hot go lower and if too cold go higher
#5837
Delta peak is a little trial and error. Just make sure the pack dosen't get too hot. If it starts over heating stop it and turn down the delta and try again. I had one pack of the original 3300's that had to be baby'd and have the delta turned way down or it would get too hot.
#5838
thanks, i just cant get over how good they are.
I have 1 question. Do you recomend using the battery packs on the Much More Racing Zero discharge tray?
#5840
It takes the voltage down to zero. The company claim that with correct usage the tray can increase the voltage between two and ten percent. I have only seen these trays in the last month and am wary of taking my packs to zero voltage.
#5841
to me that discharger is almost exactly the same as trinity's real time 2, which is just a box with some resistors
it looks cool tho, specially when you stack 4-5 together
#5842
LosiRob - I would expect to see the announcement after the worlds which Fukuyama has been very busy matching cells for. I would say probably Mid-November once everything calms down a bit at HQ. Stay tuned
John
#5844
Either one. I have a Rayspeed and love it. But I got mine long before Novak had theirs out. I guess if I were buying a new one, I'd probably get the Novak just because it's cool looking. But really, they both do the same thing. As long as it can cut off @ .9v you'll be fine.
#5845
I just got the novak smart tray, but i thought of getting the Rayspeed. I think the rayspeed looks nice as well and it has those screws instead of those tabs.
#5848
Originally posted by John Fontaine
Jon has fat butter fingers, that's why he can't work the Rayspeed screws Haha, just joking. I think the Rayspeed screws work great and I like the unit because it's small and compact, easier to fit in my Xray pit bag. The Novak would be difficult.
