Fukuyama Batteries
#5026
Thanks John for your reply!
I'm running on-road touring. Took note of your suggested rate. The delta peak you referred to is .04-.05 per cell, right? So it will come out as 30 mV delta peak on the ProTrak? I use the Temp tray only in the house because of the discrepancy that I experience when I'm at the race track because I get false peaks.
Regards.
Regards.
Originally posted by John Fontaine
Gido - Depends on what you're running. All my charging is based on touring car racing, it could be different if you run off road.
Stock - 6 to 6.5 amps charge with .04 to .05 peak detect. Cells should be around 130-145ºF after the peak.
Mod - 5 amps with .04 to .05 peak detect. Same temperature is applied to the cells after the charge, but with the 5 amps you'll have longer runtime and just a hint less of voltage. Voltage isn't an issue with mod motors, but crutial with stock.
Also, if the cells are getting to hot, reduce your peak detect.
Hope this helps.
John
Hope this helps.
John
#5027
Super Moderator
Gido, the ideal threshold will also depend on the ambient temperature, so if it's kinda hot where you are then I'd lean towards the 4mV one(which would total 24mV for the pack), & simply go higher when the temperatures permit. And even though you might get false peaks when using the thermal tray in the heat, it still might be worth keeping with you just to check the pack's temperature after it finishes charging.....oh, & Dan, many thanks for the quick reply on that Mako, it's much appreciated(& I'm sure with a little time, I'll figure out how to get mine singing the pretty notes)......
#5028
Re: Special Notice
Originally posted by Maj. Teeth
Dear Team Drivers,
Those that are planning to attend this years Reedy Race, please contact me via Email within 48 hours to get your team Spec Pack. After 48 hours, all packs will be retailed to Customers and Shops. Thanks.
Dan
Dear Team Drivers,
Dan
#5031
Hey I have found that heating the batteries up by charging them at a higher rate only gives you a quick boost at the beggining of the run. I ran Chris Tosolini's packs that I charged at 5 amps and I ran awesome from the start to the end. I was also running mod and I never dumped and had great power.
Before the preworlds I used to run trinity but had a problem making run time and I talked to Chris and he lent me 2 packs that were not even his new packs, and "I never dumped".
I will now be running Fukuyama batteries exclusively.
#5032
Congrats Sobatka on your run at the Tulsa race.
I wanted to go!!! To may races in the same month!!!!!HEHE
#5033
#5035
mako = hot !
I ran the mako as well at socal raceway, and it was super fast! But the only problem is that It gets very hot. Mine was at 180 degrees! I run a tc3, and I know the drive train is free. The gearing is 34 pinion and 100 spur. The motor show no sign of binding, and the drive train spins for like 10 seconds . Pease help! how do I get the mako cooler?
#5036
Fukuyama's powered me and my pitmate's XXX-T's to a 1-2 Losi finish this week! We were so evenly matched, I only beat him out by 0.3 seconds! Now if I can just get my buggy to behave we can try for a 1-2 finish in that too My Trinity Monster is pooping out too (I think the SMC's are shot, glitches like crazy), need to find some funds for a Mako
#5039
I've tried all ranges of pinions from 31-35 and none seem to affect the motor that much in terms of heat. It just stays hot. I've cleaned the mtor taken it apart , nothin seems wrong. PLus when I got below 34 pinion the motor just seems to be super slugish, and has no speed
