Fukuyama Batteries
Old 02-12-2004, 05:22 PM
  #3526
Maj. Teeth's Avatar
Default Stockon Race
Ok, I'm getting a little antsy and since some of you guys brought it up. I might go up to race/watch. My question is, Matt Howard, James Arluck, RCzombie and all those NorCal friends, any of you willing to take me drinking afterward?
Dan
Maj. Teeth is offline
Old 02-12-2004, 05:37 PM
  #3527
Talking HEY DAN !!
I saw what you looked like in the pic on the couch.. you sure you need another drink ???j/k
mb racer is offline
Old 02-12-2004, 07:50 PM
  #3528
dr_hfuhuhurr's Avatar
Trader Rating: 95 (100%+)
I've heard some buzz about the Rayspeed discharger. What's so special about that one over my Trinity Realtime 2. Other than the obvious, the Rayspeed is not made by big t?
Blake
dr_hfuhuhurr is offline
Old 02-12-2004, 07:59 PM
  #3529
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Does the realtime cut off at .90v per cell. I think it takes them down to 0v like most of the others.
Jon Kerr is offline
Old 02-12-2004, 08:03 PM
  #3530
DavidAlford's Avatar
Trader Rating: 32 (100%+)
The Trinity realtime? It takes them down to zero as far as I know. Least thats what I always thought.
DavidAlford is offline
Old 02-12-2004, 08:08 PM
  #3531
Sal Amato's Avatar
Trader Rating: 27 (100%+)
Post
I have a realtimee 2 tray. I just remove packs when the lights go out.Thats what it says right on the tray itself not really sure if it has a specific cut off.seeing that there is lights bulbs and a fan the tray will probably just drain batteries until the power is not sufficient enough to run the fan ,Who knows what that is.
Sal Amato is offline
Old 02-12-2004, 08:15 PM
  #3532
Sal Amato's Avatar
The rayspeed discharger has a cutoff ,speedtech has them on there website with some specs.
Old 02-12-2004, 08:17 PM
  #3533
RCTech Member #2
TSR6's Avatar
sns - realtime2 takes the cells down to zero, it is a pure resistor equalizer. You want to take the cells off when the bulbs go out for GP cells, unless you want to deadshort the cells.
TSR6 is offline
Old 02-12-2004, 08:21 PM
  #3534
KevanB's Avatar
Does the Pro Match Racing Smart Tray 2 have auto cut off? It doesnt look like it does. All I see on it are diodes and resistors.
KevanB is offline
Old 02-12-2004, 08:36 PM
  #3535
Matt Howard's Avatar
Blake
IMO the Rayspeed discharger is the best out there right now. It's adjustable from a 5 amp to 1 amp discharge and the cutoff is adjustable from .9 per cell to .1 per cell
Matt Howard is offline
Old 02-12-2004, 09:03 PM
  #3536
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Default Re: Stockon Race
Dan
You better make this one Dan man Let me know if you'll want to ride up there in the Subie or if you'll make it up there later in the weekend.
Randy Caster is offline
Old 02-12-2004, 09:11 PM
  #3537
JohnMatrix's Avatar
Originally posted by JohnMatrix
Well I just bought my first Fukuyama Batteries and I cant wait to try them out.
And they aready ship me my premade batteries, this place fing rocks!
JohnMatrix is offline
Old 02-12-2004, 09:37 PM
  #3538
mike_Webb's Avatar
I got one of the Rayspeed Dischargers at Snowbirds. What I have noticed is that when I was charging my packs down there, when I did not deadshort them I was getting anywhere from 3750MAH to 3995MAH. My deadshorted cells get usually 3600MAH - 3700MAH. It didn't matter if it was the first charge or the second Charge. I now equalize all my packs before the first charge and the second charge for the day. If I want to deadshort them then I throw them on my Integy discharger that takes them down to 0.
Before I would take my cells down till my Integy Disharger Bulbs would go out and then I would charge them for the first charge of the day. After the Run I would take it down to 5.4volts on my GFX and charge them a second time. That way I was getting about 3500MAH on the first Charge and about 3300-3400MAH on the second Charge
mike_Webb is offline
Old 02-12-2004, 09:55 PM
  #3539
Dan
I don't think that would be a problem I have to drive back friday after practice for my daughters birthday but I'll probably get a hotel room with a couple friends for saturday night. I'll let you know where we're staying so you can stay there too
Old 02-13-2004, 02:05 AM
  #3540
Hey Kevin, if memory serves me right...(it's been a while since I had one) the pro-match smart trey discharges at .75amps with a cutoff at .9 volts.......
Joe B is offline
