Like Tree51Likes
Reedy!
Old 04-03-2008, 10:30 AM
  #151
Rick Hohwart's Avatar
Originally Posted by metalracer2
do you know how they sent the motor? Ups or Fedex
It would have been shipped by UPS.
Rick Hohwart is offline
Old 04-03-2008, 09:44 PM
  #152
metalracer2's Avatar
Trader Rating: 20 (100%+)
i got my motor back today
that was a quick turn around
you guys have any idea what would have caused that?
metalracer2 is offline
Old 04-04-2008, 07:56 AM
  #153
It looked like the balance hole was drilled off center and weakened the armature laminations.
Old 04-04-2008, 09:54 AM
  #154
dizzy1's Avatar
Trader Rating: 29 (100%+)
Rick,
Since you mentioned in other threads that you have been trying different methods of charging and performance with the Reedy 5000 lipo, do you have any recommendations. I'm looking for maximum performance, not long life. What amps are you charging and what level are you leaving the pack each week, do you charge it back up to a certain voltage? Any reports on warming or if it seems stronger on the second/third charge for the day?
dizzy1 is offline
Old 04-04-2008, 01:04 PM
  #155
Originally Posted by dizzy1
Rick,
Different batteries react differently to heating. The Reedy LiPo seems to produce maximum performance when pre-heated a charged pack to 100F before use. At the Carpet Nats I did not pre-heat my battery and felt as fast as anyone in the 10.5 class where I finished 5th overall. I think if I had pre-heated my battery I would have had an even faster car. I ran each battery 2 times per day and three timer per day in practice. i did not notice any differences in performance related to the daily cycle number.
Charge the battery at 1C (5 amps) to 8.44V, use a good connector and wire your car so the wires are as short as possible. I store the batteries at about 50% capacity.
We have some other tricks for LiPo but willnot disclose those at this time. When testing is complete we will post a Competion User's Guide on our website.
None of these sugegstions will reduce the life of the battery.
Old 04-06-2008, 12:52 PM
  #156
Maybell's Avatar
Rick,
Just curious what connector you are using? I was thinking of trying the Traxxas connector or good ol' Deans...
Maybell is offline
Old 04-06-2008, 01:04 PM
  #157
Thumbs up
well i ran the stockstar last night and it ran great. i ran it with the suggested gearing, it was a little on the hot side but i heard they like to run hot.
Old 04-06-2008, 01:05 PM
  #158
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
just wanted to say i ran the stockstar at the first JBRL, qual'd and finished 4th in the A-main (the mains went all the way to D). Ran pretty good as ive said, just wish i had more tuning options via brushes. Cant the existing compounds be had in larger blocks/chunks and cut to the dimensions as the stockstar brushes? That would be sweet, some stockstar 767 compounds...or something...
anyways keep up the good work
Syber Serulean is offline
Old 04-08-2008, 07:51 AM
  #159
Originally Posted by Maybell
Rick,
I use Deans. The TRX should be good or even the golt tube type connectors as long as you are careful about polarity.
Great! The best place to check for heat is the brushes and commutator. If the motor feels hot, but the comm and brushes look good (no discoloration), you are geared correctly.
Great result! Brush development continues. Some ofthe vendors we have used have changed hands so it is like we are starting over from scratch in rfegards to brushes and compounds. So it is taking longer than expected. But hopefully we will have something this summer.
Old 04-12-2008, 11:50 PM
  #160
Gidday Rick,
Have the new "Roar Legal" 50840 13.5 LRP motors been shipped to any shops yet? It just seems impossible to buy one and frustrating when you have one on order.
Regards
Mike
ixlr8nz is offline
Old 04-14-2008, 07:31 AM
  #161
Originally Posted by ixlr8nz
Gidday Rick,
Regards
Mike
They have been shipped, but in small quantities. Have you ordered from a U.S. shop? Which one?
Old 04-14-2008, 12:08 PM
  #162
Gidday,
I ordered one from rcplanet and they have it on backorder. Which shops have they been sent to?
thanks
Mike
ixlr8nz is offline
Old 04-14-2008, 02:23 PM
  #163
Gidday,
thanks
Mike
Typically they will go to distributors and then on to shops so I can't say for sure who has them. I do know that HobbyTown USA Hobbyplex Raceway in Omaha Nebraska has/had them.
Old 04-15-2008, 07:33 PM
  #164
dizzy1's Avatar
Rick,
Have the Reedy Lipo Pro packs come in from overseas? I think I remember a mention about the 8th of this month, but I still don't see any places having them in stock. Just want to see if they hit the distributors yet or not.
dizzy1 is offline
Old 04-16-2008, 07:30 AM
  #165
Rick,
They have arrived last week and have been shipped to distributors in LARGE quantities. They should be showing up in stores any day now.
