Axiom Motors
#1385
Dave, you got PM...
#1386
Any updates on the EP cells? Thanks
#1388
yup, gotta new tire rag...lol just playn' oh yah, Erlich got one too...can you say "RIG"
mmmmmm...what a hot trophy chick!
#1393
as the owner and official sponsor of your new ride.....
front
toe 1/2 deg out
camber -1.5
oil 60 or 70
ride height 4.5mm
droop 1.5mm
couplers dot down
camber link rods up and out
rear
toe 2 deg in
camber -2.0
oil 30
ride height 4.5
droop 2mm
couple dot down
camber link up and out
look on the RDX thread for other setup tip's
front
toe 1/2 deg out
camber -1.5
oil 60 or 70
ride height 4.5mm
droop 1.5mm
couplers dot down
rear
toe 2 deg in
camber -2.0
oil 30
ride height 4.5
droop 2mm
couple dot down
#1394
front
toe 1/2 deg out
camber -1.5
oil 60 or 70
ride height 4.5mm
droop 1.5mm
couplers dot down
rear
toe 2 deg in
camber -2.0
oil 30
ride height 4.5
droop 2mm
couple dot down
front
toe 1/2 deg out
camber -1.5
oil 60 or 70
ride height 4.5mm
droop 1.5mm
couplers dot down
rear
toe 2 deg in
camber -2.0
oil 30
ride height 4.5
droop 2mm
couple dot down
Added all the Lunsford stuff to it as well, hopefully it will rock... Have a ton of ballstuds to put on it still
Did notice the foam rims rub on the bottom of the front shocks
#1395
