pls join me and pls take a look!!!!!!!
I am hopeing that you guys and sweet lady will like to join in the fun of rc nitro on-road bike whice was a 1/5 bike it was a nitro bike you can find the bike selling at rotorhobby Thunder Tiger 1/5th Scale Nitro Bike
to see the bike pls clike here--〉http://www.storacingproducts.com/cg...wprod_TT6301F31
and here is the price and some pics of the nitro bike --〉http://shop.rotor.com.sg/show-detail.asp?prodid={8FA0B692-C06E-4772-8412-3CA36A3E8E36}
New! Ready To Run Just Needs Fuel And AA Batteries!
The Ducati 999R is a true race bike for the road, its link between the standard production bike and the racing world where Ducati have dominated World Super Bikes. Ducati have created a cult following from which the Thunder Tiger bike was born.
It arrives 100% assembled with the engine and all R/C equipment pre-installed. A unique ride is achieved by an aliminum spring loaded front fork and fully functional rear swing arm, just like the real thing!
Features:
100% factory assembled and factory painted shell (high impact) with realistic vinyl rider figure
Powerful Pro-12BK (2.11c.c.- 0.129 cu.in.) engine with hex starter
Patent dual spring loaded and oil-filled steering damper
Aluminum spring loaded upside down front fork
Aluminum rear oil-filled adjustable mono shock
Aluminum rear disc brake system
Aluminum front and rear wheels w/ high grip slick tires
Aluminum side frame
Aluminum rear arm swing
Fully functional steel drive chain and sprocket w/ ball bearings
Circular, roll-over protection wire
Unique two exhaust aluminum muffler & tuned pipe
Specifications:
Lenght: 413mm
Width: 116mm
Height: 200mm Wheel
Base: 295mm
Front Wheel: 110mm
Rear Wheel: 127mm
Weight: 2200g(w/servo,receiver,engine)
Engine: PRO-12BK •
Radio: 2CH
Features:
Aluminum side frame
Specifications:
Lenght: 413mm
Width: 116mm
Height: 200mm Wheel
Base: 295mm
Front Wheel: 110mm
Rear Wheel: 127mm
Engine: PRO-12BK •
Radio: 2CH
