ESC: mc330cr
Old 10-02-2002, 09:15 PM
Default ESC: mc330cr
i have a problem on programmimg my esc.
hope u guys can help mi.
the moment i switch on the power, my esc keeps on beeping rapidly even b4 i press the pushbutton switch.
i couldnt carry on with my normal programming.
ani1 encounter similar problem?
rx-7 is offline
Old 10-03-2002, 12:45 AM
HZM
Make sure throttle trim is neutral, hold down the push button for 1 second, then try programming again. It is brand new?
HZM is offline
Old 10-03-2002, 02:10 AM
plug it in the right polarity?
HuFFy is offline
Old 10-03-2002, 03:24 AM
1st hor, you got read the manual and wire the esc correctly or not ? You got to follow every step in the instruction. Mai kan cheong. got a lot of time to play hor. if you wire the esc wrongly, let's say the wire for motor, you wire to the batteries then everything will be wrong. 2nd hor, you must check whether your battery is full whether it is the esc or transmitter battery.
3rd hor, try to hold down the program button and restart again lor.
Freak is offline
Old 10-03-2002, 03:45 AM
fIShCaKe's Avatar
Ya sure ya did switch on ya Transmitter? Hmm, the 330 on my brother's car also beeps..... when I switch on the car before I switch on the transmitter. Do check if ya did switch on ya 330.
Try holding down ya one-touch button after which, then release, doing the usual set up.
fIShCaKe is offline
Old 10-03-2002, 05:57 AM
Default esc
ya, i did switch on my transmitter b4 my car.
push down the button also no use, doesnt stop the rapid beep.
1st i also thought is the polarity problem so i switch the wire but still the same.
well, the wheels do move forward abit by abit when the esc is on, is this normal?
no, the esc is not new.
rx-7 is offline
Old 10-03-2002, 06:03 AM
GTO2's Avatar
set throttle switch to 'reverse' at the transmitter.
GTO2 is offline
Old 10-03-2002, 09:27 AM
hey guys, i have solve the problem.
its the switch harness. somehow it's damage.
so i just plug the esc directly to the rx. n not through the switch harness then the rx.
now the esc works fine. thx
rx-7 is offline
