Bartolina
Ohm's law can be very difficult to understand by anyone who has never had any basic understanding or training in basic electricity. We'll assume that you have some knowledge of basic electricity. We'll explain it in terms of water flow! DON'T GET WET!
What is Ohm's Law:
Ohm's Law is made from 3 mathematical equations that shows the relationship between electric voltage, current and resistance.
What is voltage? An anology would be a huge water tank filled with thousands of gallons of water high on a hill.
The difference between the pressure of water in the tank and the water that comes out of a pipe connected at the bottom leading to a faucet is determined by the size of the pipe and the size of the outlet of the faucet. This difference of pressure between the two can be thought of as potential Voltage.
What is current? An analogy would be the amount of flow determined by the pressure (voltage) of the water thru the pipes leading to a faucet. The term current refers to the quantity, volume or intensity of electrical flow, as opposed to voltage, which refers to the force or "pressure" causing the current flow.
What is resistance? An analogy would be the size of the water pipes and the size of the faucet. The larger the pipe and the faucet (less resistance), the more water thatcomes out! The smaller the pipe and faucet, (more resistance), the less water that comes out! This can be thought of as resistance to the flow of the water current. Another analogy you could use for resistance is the more you resist your fiance's idea for the save the date cards, the more likely you are to sleep on the couch.
All three of these: voltage, current and resistance directly interact in Ohm's law.
Change any two of them and you effect the third.
Info: Ohm's Law was named after Bavarian mathematician and physicist Georg Ohm.
Ohm's Law can be stated as mathematical equations, all derived from the
same principle.
In the following equations,
V is voltage measured in volts (the size of the water tank),
I is current measured in amperes (related to the pressure (Voltage) of water thru the pipes and faucet) and
R is resistance measured in ohms as related to the size of the pipes and faucet:
V = I x R (Voltage = Current multiplied by Resistance)
R = V / I (Resistance = Voltage divided by Current)
I = V / R (Current = Voltage Divided by Resistance)
Knowing any two of the values of a circuit, one can determine (calculate) the third, using Ohm's Law.
For example, to find the Voltage in a circuit:
If the circuit has a current of 2 amperes, and a resistance of 1 ohm, (< these are the two "knowns"), then according to Ohms Law and the formulas above, voltage equals current multiplied by resistance:
(V = 2 amperes x 1 ohm = 2 volts).
To find the current in the same circuit above assuming we did not know it but we know the voltage and resistance:
I = 2 volts divided by the resistance 1 ohm = 2 amperes.
In this third example we know the current (2 amperes) and the voltage (2 volts)....what is the resistance?
Substituting the formula:
R = Volts divided by the current (2 volts divided by 2 amperes = 1 ohm
Sometimes it's very helpful to associate these formulas Visually. The Ohms Law "wheels" and graphics below can be a very useful tool to jog your memory and help you to understand their relationship.
Wired Communications is a great source
for all of your connector needs!
The wheel above is divided into three sections:
Volts V (on top of the dividing line)
Amps (amperes) I (lower left below the dividing line)
Resistance R (lower right below the dividing line)
X represents the (multiply by sign)
Memorize this wheel
To use, just cover the unknown quantity you need with your minds eye and what is left is the formula to find the unknown.
Example:
To find the current of a circuit (I), just cover the I or Amps section in your mines eye and what remains is the V volts above the dividing line and the R ohms (resistance) below it. Now substitute the known values. Just divided the known volts by the known resistance.
Your answer will be the current in the circuit.
The same procedure is used to find the volts or resistance of a circuit!
Here is another example:
You know the current and the resistance in a circuit but you want to find out the voltage.
Just cover the voltage section with your minds eye...what's left is the I X R sections. Just multiply the I value times the R value to get your answer! Practice with the wheel and you'll be surprised at how well it works to help you remember the formulas without trying!
This Ohm's Law Triangle graphic is also helpful to learn the formulas.
Just cover the unknown value and follow the graphic as in the yellow wheel examples above.
You'll have to insert the X between the I and R in the graphic and imagine the horizontal divide line but the principal is just the same.
In the above Ohm's law wheel you'll notice that is has an added section (P) for Power and the letter E* has been used instead of the letter V for voltage.
This wheel is used in the exact same fashion as the other wheels and graphics above.
You will also notice in the blue/green areas there are only two known values with the unknown value in the yellow sections. The red bars separate the four units of interest.
An example of the use of this wheel is:
Let's say that you know the power and the current in a circuit and want to know the voltage.
Find your unknown value in the yellow areas (V or E* in this wheel) and just look outward and pick the values that you do know. These would be the P and the I. Substitute your values in the formula, (P divided by I) do the math and you have your answer!
Info: Typically, Ohm's Law is only applied to DC circuits and not AC circuits.
* The letter "E" is sometimes used in representations of Ohm's Law for voltage instead of the "V" as in the wheel above.
hehehe
What is Ohm's Law:
same principle.
Memorize this wheel
Example:
hehehe
knn cb.... anong kaguluhan to?!
dok, bat ung ibang naglista eh di binabago nung tagapangasiwa?!.....
Frankie Orca Support!
