Yokomo DRB Drift Chassis
#49
#51
#56
#57
Make: YOKOMO
Model: DRB
Track surface: painted concrete (York R&D Drift Circuit) Jalan Ampart
Tire: T-Drift
Motor & ESC: SP GT2pro,Novak 7.5T
Front
Camber: 6deg
Toe: 0
Kick up: 5mm
Caster hubs: 4deg
Ride height: 6mm
SpringsRB Stock black Dot(hard)
Bumper weight: 0
Trailing Steering Block: stock
Sway-Bar: none
Shock Oil: caster 45w
Other:
Rear
Camber: 3deg
Toe: -3deg
Kick up: none
Ride height: 5mm
Springs: soft
Sway-Bar: nil
Shock Oil: caster 40W
Other:
Drive Train
Gearing:
Front 1-way/Rear Spool
Front: stock 40t
Center:stock 15t
Rear: yokomo cs 20t
Center:stock 15tT
Spur: 82T/48 pitch
Pinion:19T/48 pitch
Ratio: 2.0%
______________
Model: DRB
Tire: T-Drift
Front
Camber: 6deg
Toe: 0
Kick up: 5mm
Caster hubs: 4deg
Ride height: 6mm
Bumper weight: 0
Sway-Bar: none
Other:
Rear
Camber: 3deg
Toe: -3deg
Kick up: none
Ride height: 5mm
Springs: soft
Sway-Bar: nil
Other:
Drive Train
Gearing:
Front: stock 40t
Center:stock 15t
Rear: yokomo cs 20t
Center:stock 15tT
Spur: 82T/48 pitch
Pinion:19T/48 pitch
Ratio: 2.0%
______________
#58
Make: YOKOMO
Model: DRB
Track surface:Polish tiles (Woodland Underground)
Tire: T-Drift
Front
Camber: 6deg
Toe: 0
Kick up: 5mm
Caster hubs: 4deg
Ride height: 5mm
Bumper weight: 0
Sway-Bar: none
Other:
Rear
Camber: 2deg
Toe: -3deg
Kick up: none
Ride height: 6mm
Springs: Med
Sway-Bar: nil
Other:
Drive Train
Gearing:
Front: stock 40t
Center:stock 15t
Rear: yokomo cs 20t
Center:stock 15tT
Spur: 82T/48 pitch
Pinion:19T/48 pitch
Ratio: 2.0%
Model: DRB
Tire: T-Drift
Front
Camber: 6deg
Toe: 0
Kick up: 5mm
Caster hubs: 4deg
Ride height: 5mm
Bumper weight: 0
Sway-Bar: none
Other:
Rear
Camber: 2deg
Toe: -3deg
Kick up: none
Ride height: 6mm
Springs: Med
Sway-Bar: nil
Other:
Drive Train
Gearing:
Front: stock 40t
Center:stock 15t
Rear: yokomo cs 20t
Center:stock 15tT
Spur: 82T/48 pitch
Pinion:19T/48 pitch
Ratio: 2.0%
