enquiry on lipo batts
hey all. i am converting to lipo and want to know more before doing the change.
what is 20c, 25c and 30c. what does these means.
how about charging the batt, what must be taken note.
any mods needed to be done for my car, esc and motor.
what type of charger is needed
and balancing.
thanks=)
and balancing.
thanks=)
The C ratings are simply a way of talking about charge and discharge rates for
batteries, the higher u get the faster it drains out.
Always balance charger the batteries, it helps in the long run.
Use Deans connectors their good enough.
Any Li-po charger that can balance charger is all u need.
Hope this helps
Hope this helps
Hope this helps
Hope this helps
Yes that is add on. Or your ESC may come with Lipo cut off, meaning that when one of your cell drop below a certain voltage(which you can set), you cannot throttle anymore.
[QUOTE=andylim_123;7707461]Yes that is add on. Or your ESC may come with Lipo cut off, meaning that when one of your cell drop below a certain voltage(which you can set), you cannot throttle anymore.[/QUOT
okie. than can all esc take lipo batts be it BL or Brushed and do i need to do and mods to the esc or batt or motor if i convert. i know i have to modify my chassis.
what else do i have to do
also what is the best esc for drifting
oh and is belt better for drifting or shaft?
Both belt and shaft is ok for drifting and esc it better to go with BL wth sensored will be good.
