MO3 owners fall in!
#106
#107
#108
Mini meets
4 x M03M will be at BK Friday Nite 25/1... hope to see many more.
#109
i'll be there on saturday
just converted my suzuki to cooper
#110
60D Super Grip
Hi gtsfrost,
Lets see, if you are thinking of racing, the M03R will be a good start point although the M03M Suzuki Swift is also a good choice. The R is value for money. Suzuki Swift got lower starting cost. R is about 280++ the Swift is about 200.
R comes with alum uprights, oil dampers, tuned springs, turn-buckles, aluminum heat sink and servo mounts. Full ball bearings. But No shell.
Suzuki Swift comes with a shell and no oil dampers, but has a ESC. Wheel ball bearings only. Suspension is similar to R except rear toe angle is 2 instead of 1.5. you will need to buy CVA Super Mini dampers, will cost about 40 for 4pcs.
Both kits will need the all important TA03 ball diff. For racing, 60D Super Grip tires with hard inserts will be good.
I think i'm writing too much. Why dont you read up on the 2 kits at tamiya.com and figure out what you want.
Keep hearing from you guys about 60D Super Grip tires, white box Super Slick tires.... Btw where you guys get hold of these high grip tires. Go bk and stargek only got m-grip, radial and those super fast wear slicks leh.
#111
I bought mine from BK. Ask Bk to indent for you. If not can also ask winnie swan models to indent for you.
#112
#114
I am interested to get a M chasis car to play with. Looking at the ABC Hobby's Muden Fit Spec D kit. Where can i buy this locally?
#115
yeah.... but no but yeah but no...
super grips are the best at the mo...
problem is, the only way to get them is to buy them off the internet.
there are no s-grips here avialable... it sucks.
looks like the best way to buy stuff is still off the net. it's just too bad the local shops dunt stock enuff tires to support a racing program.
oh well.
looks like no playingin TAC or the pre-TAC then...teehee
i was looking forward to using my m04...
happy new year everyone!
-alexander
oh well.
-alexander
#116
Discoburg, you might want to check out with BK whether he has one anot...O
Foamie, I agree with you...
#117
May i ask what is the difference with the M04, M04M, M03, M03M & M03-L?
#119
M04 are rear wheel drives while the M03 are front wheel drives...
The M or L behind the M03/4 indicates the length of the chassis provided...
If you have a M03M, you can just remove the middle extension to convert to a M03 and you might have to buy a longer extension to do a M03L...
FYI, M03R comes with both extension parts to use all 3 wheelbases...
#120
Hmmm!!!
im guessing only dont know if its right
if MO4 is rear whell drives and MO3 is front rear drives.
MO4 has an advantage in long straight than MO3 (im talking about the car not the drivers )
am i right? again its only a guess
