MO3 owners fall in!
#196
WAHAHAHA....
Ask Dr Khng, he got those power N95 masks!
Good Luck to all of you TAC Competitors, although I can't make it this time, you will have my full mental support!
Oh ya, if you guys need any equipment just let me know, if Weiquan or Khng haven borrow, can pass them to you!
GO GO TEAM SINGAPORE!!
#197
Come on bros Ray Lan, Kail and GKC... Let set a date & timing to gather all m03 players here to fill up BK track!!
#198
Trader Rating: 23 (96%+)
also have any1 tried this?
http://www.hobbywing.com/english/Art...?ArticleID=419
http://www.rc-mini.net/MiniWeb_Online/Hobbywing.html
s grip is it the same as those stock out of box tyre? i did notice the swifts tyre are stuff? double insert?
#199
S grip are option tyres from tamiya. Ride height should be abt 4mm.
Hhaa ok when we return we shall gather k.
Anyway bad news: Motor god from thailand is racing against us in TAC in mini. How NICE... I never expected this day... haha
#200
#201
thanks a lot....racing TAC, good luck, might go if got time...
#202
Errr...
Do you guys welcome non-Tamiya brand mini chassis here?
Play for fun only, looking for kakis.
#203
I am confident that your experience with the M03, setting up and driving, is capable of bringing home the Gold.
Kai, my final word of advice is:
Don't let anyone intimidate you!
You are only there for 1 reason, to beat EVERYONE else, doesn't matter who he is.
#204
Thanks to the 2 bros (sorry did not get your names) who helped me alleviate the traction roll problem at BK this after. My wife's pretty happy with her car now
With stiffer springs in rear and some changes to TX settings can much lesser pitching and roll during on power into corner, but still wanna try to reduce the pitch and roll further, more pointers?
"Mini" Bros, care to share your suspension setup?
Shock Type - TRF, CVA?
No. of piston hole (F/R)?
Shock oil weight (F/R)?
Springs (F/R)?
No. of O-ring/limiter?
On measuring ride height for the Mini, just measuring the front and rear most end of the chassis and keeping the ride height balanced is sufficient?
Springs (F/R)?
No worries for the help.Happen to be there and saw u struggling.Most of the time, tires 'help' with traction rolling.So getting correct tyres will help. Tamiya S grips seem to work fine, like most ppl are running here.
But if u wan to get aftermarket tyres, get from 28r to 32r mini tyres. Run ur favourite inserts and u'll be fine.
My own setup ( others will differ )
Shock Type - TRF or super mini CVA.(doesnt matter which one,juz build it to instructions)
No. of piston hole (as per instructions)
Shock oil weight (as per instructions - kit tamiya package is 900 or 90 equivalent.Anything extremely lesser would make the mini 'lazy' in transitions.)
Springs (Blue on both ends)?
No. of O-ring/limiter? ( as per instructions - put the longer 6mm plastic spacers dat come on the parts tree.O rings, in my opinion, gives inconsistent results.)
Someone said a ride height of 4mm would be alrite.I'd think u can start from there and c if u like it..
regards
Evil Ernie
#205
where are the race tomorrow? were drop by if i have the time... ( saw the mini rover for the first time, love it and buy it on the spot. my first rc car )
#206
If you want to see, there is one coming up at Novena.
http://www.rctech.net/forum/singapor...ep-2008-a.html
#207
yap bro they are in Malaysia....gogo team singapore.. lolx anyway we will be playing minis at BK track on fridays nites and sat nites.. hope to see u all there
#208
hye guys.....i play at BK last tuesday...the pink swift.....play on day time la...i do believe one off u guys gave some advise...thanks a lot bro...(white swift) quit shy to play actually....hihihihihi....
anyway thanks guys......really get some tips reading this thread....
#209
Do drop by more offen to join the mini FUN!! Cheers!!
