T15 batt charger
#31
the good chargers will overcome this by having software programs that prevent false peak.
also, some batteries are by nature, prone to false peaking... if cells are no so healthy, it'll happen more often...
that's the current problem with the high capacity nimh batteries... that's why a lot of ppl now switch to li-po or li-ion... maintainence free, and hold their charge almost forever....
#32
the A123 lithium-ion cell max charge voltage is 4.10v per cell. not sure if the T15 has a li-ion function... if have, then can lah... some chargers only says 'lithium', but never say lithium-ion or li-po... if can adjust the CV voltage to 4.10v, then it should be fine....
by the way, li-po max charge voltage ranges from 4.20-4.25v, depending on the manufacturer...
#33
#34
What TX u using?
#35
like what i mentioned earlier, A123 is a cell size, not the chemistry of the battery... but the A123 from hyperion is li-ion... not sure of the spec though... if they say can charge at 2-3c, then it should be fine... if the T15 can charge li-ion, then can use loh....
#36
hi,
can T15 charge those 12V motorcylce battery used for starter boxes?
#37
#38
#39
Can T15 charger run in new motor like 540j or black can
#40
Can the T15 charge Li-Fe batteries?
#41
#42
maybe u can try to charge ur friend lipo and see if the prob persist.. if not, then i suspect ur lipo batt.
