pulls to the right when braking
If the shocks, stops and springs aren't it, look at your pivot points.
A lower broken/bent hinge pin would do the same. Bearings would be my next step beyong the pins.
Arent you also the one who posted that you thought your chassis was bent from the factory? You need to definetly set your tweak. Go to mytsn.com and read their articles on a few of these things, you will learn alot that you should know and will make your car better handling.
