Weight Distribution - How to do perfectly? >
Old 04-09-2004, 01:39 PM
Registered User
Default Weight Distribution - How to do perfectly?
I use Integy digital weight distribution gauge. Here's the 4 wheels weight of my sd.
LF= 462g -------- RF= 178g
LR= 208g -------- RR= 498g
LF+LR= 670g ------ RF+RR= 676g
I have 28% cross weight [(RF+LR)/total weight]. According to integy worksheet, my car will "push right turn".
If I put more weight on LR and RF, I have to put more than 200g of lead for each. Am I right? How do you guys make your chassis balanced? Is it adjust the droop?
Aku-Man is offline
Old 04-09-2004, 02:05 PM
Brandon R's Avatar
i think it is measuring wrong...i dont see how in the world it can come out to those numbers! I got 4 digi scales off ebay that do 1000grams each and comes out pretty close without even tryin to balance... i would check that thing integy thing out...dont sound right!!
Brandon R is offline
Old 04-09-2004, 02:20 PM
Sounds like a big tweak in the chassis, rather that a balence issue.
MattW is offline
Old 04-09-2004, 02:35 PM
s2
s2's Avatar
are there any other ways to measure weight distribution other than the 4 scales method?
s2 is offline
Old 04-09-2004, 02:43 PM
Speedie's Avatar
Default Re: Weight Distribution - How to do perfectly?
Nothing wrong with a little confusion. You would be surprised at some of the people running 50 thousand dollar full scale race cars that dont understand this. First thing to do is set your ride heights, be as precise as you can. Then scale it. first thing to set is front/rear and Left/ right balance. No matter how much you jack on the coilover it wont change these percentages. These have to be set with physical weight placement in the car. I have been running my TC3 with 51% front weight. It all depends on how you drive. More front more steering, more rear more rear traction. Your almost perfect left right and your at 52% rear as it is. alwayse push down on the chassis before you take a weight to settle the suspension.
Once you get that done set your ride heights again. Now this is the part that people dont understand. You can jack your wedge into shape without changing ride heights much. You have to adjust all 4 collars at the same time. What your trying to do is get the front and rear numbers equal. You need weight on the right front so you would put a turn in the RF and LR and take the same amount out of the LF and RR. This will shift the wedge without changing ride height. Dont make big adjustments I wouldnt do more than a turn at a time till I went over, then back 1/2 turn and so on till its right.
Alwayse keep checking ride height if you make alot of changes. With the L/R at 50% and ride height set acurately you shouldnt have to adjust much to get it perfect if those two things are right.
Speedie is offline
Old 04-09-2004, 02:54 PM
Speedie's Avatar
One thing I forgot. Depending on what springs you are using you might have to adjust different. On a full scale dirt car the front springs are twice the rate of the rear springs so you turn the front springs half the amount you do the rear when adjusting wedge. Since the spring is doing twice the work. I never run a big split on a touring car so I adjust them the same. If you have a big split front to rear you might have to adjust how much you adjust each.
Speedie is offline
Old 04-09-2004, 03:22 PM
Registered User
This time I loose all the screws and retie them. re-do the ride height.
LF= 406g------RF= 250g
LR= 286g------RR= 424g
Is shock oil or spring have to be same at front and rear?
Aku-Man is offline
Old 04-09-2004, 03:25 PM
Speedie's Avatar
I would just start adjusting one turn in RF and LR and one out of LF and RR
For onroad the oil and springs have to match on each end front same, rear same.
Speedie is offline
Old 04-09-2004, 03:35 PM
Registered User
after adjusting,
LF=368 RF=278
LR=314 RR=368
So, just keep adjusting collars till they all match?
Aku-Man is offline
Old 04-09-2004, 03:40 PM
Speedie's Avatar
Yes, once they are even set ride height again. Then adjust again, till ride height is right after it scales right. Its a pain but when its right it will be worth it.
Speedie is offline
Old 04-09-2004, 03:44 PM
Registered User
Do I need to add weight to RF and LR to make less adjustment?
Aku-Man is offline
Old 04-09-2004, 03:49 PM
Speedie's Avatar
Nope the only thing to add weight for is getting R/L and F/R percentages. All your really doing is setting tweak just alot more accurately.
Speedie is offline
Old 04-09-2004, 03:52 PM
Registered User
Thanks SpeediePHATT
Aku-Man is offline
Old 04-09-2004, 03:56 PM
Speedie's Avatar
Not a problem hope it helps. Ive been thinking of getting the Integy weight station, do you like how it works?
Speedie is offline
Old 04-09-2004, 04:03 PM
Registered User
I like it, very small, but very very sensitive.
Aku-Man is offline
