Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 06-18-2003 | 09:58 PM
Default Tamiya mini cooper
Who has some setup tips and what mods you did. TCS mod tips which work or what setups are popular. More concerned on M03 or M04.
sipaboy is offline
Old 06-18-2003 | 10:18 PM
WC's Avatar
WC
Firstly check out...
TAMIYAUSA Built to Win
WC is offline
Old 06-19-2003 | 11:25 PM
hellangel's Avatar
does anyone know if the counter gears inside the gearbox of the M03 are the same as the counter gears of the TL-01 chassis??
also, if they are the same, would i be able to use the TL-01's speed tuned gear set inside the M03??
thanx
hellangel is offline
Old 06-20-2003 | 01:32 AM
WC's Avatar
WC
thanx
No and No.
But there is a Jap company that made (or used to make) a speed-tuned (higher ratio) gearset for the M03. Can't remember who, one of the usual suspects.
How high do you want to gear your car anyway??
WC is offline
Old 06-20-2003 | 10:56 AM
utieh's Avatar
integy has it , take a look a their site
utieh is offline
Old 06-20-2003 | 11:24 AM
Sipa give me your e-mail address and I can send my set-up from TCS Nats last year. It is aggressive for M04 but for TA it was by far the fastest car about .5 a lap
[email protected]
For TCS you cannot change the counter gears but for local club etc. you would be able to
Difuser is offline
Old 06-20-2003 | 05:49 PM
hellangel's Avatar
thanx for the info guys...
Old 06-20-2003 | 06:37 PM
Thanks too. Another issue. M03 or M04?
sipaboy is offline
Old 06-21-2003 | 08:48 AM
Pick up the rear wheel drive MO4, it handles much better....
IMPACTPLAYR is offline
Old 06-21-2003 | 03:03 PM
OVA's Avatar
OVA
Put it this ways..Mo3 is good for short track and Mo4 for the longer track...mo3 front drive, pulled better out of the corner speed...the mo4 is great for high gearing speed..I hope this help
scottybob likes this.
OVA is offline
Old 07-03-2003 | 09:36 PM
dirk's Avatar
Hey guys! I have a Mini (M-03), I really like it.
Just onre thing though, it seems to really understeer, which is easy to drive but I like to have slight oversteer, is that possible with a front drive car?
dirk is offline
Old 07-03-2003 | 09:38 PM
hellangel's Avatar
i'm having the same prob also... severe understeer...
Old 07-03-2003 | 09:45 PM
fatdoggy's Avatar
FWD = Push, Understreer
RWD = Oversteer
Try using hard springs on the rear and lighter springs on the front as well as decient tyres. I've heard the hpi x patterns (for the hpi mini) work well.
fatdoggy is offline
Old 07-25-2003 | 08:02 PM
dirk's Avatar
Thanks for the tip Fatdoggy. The car works much better now, it's actually faster than my f201!!
It really flies with a 12 turn motor, and shreds tires like crasy, just one thing, I need a new diff. The spider gears in the stock one have disapeared and left behind a ton of metal flakes, anybody know where to find a ball diff?!?!
dirk is offline
Old 07-25-2003 | 10:28 PM
minicooper's Avatar
From: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
TA03 ball diff fits or even the Manta Ray diff fits
Someone correct me if I'm wrong but I'm sure there were more M03's at the Tamiya TCS in Aliso.
minicooper is offline
