Team Tekin New Speedos
#61
I apologize for my regurgetating of misinformation. I'm sure they can be driven I was told that there may/was a side effect. I don't doubt the info from you though.
As far as the cap goes. You could have a clip on affair of sorts, like a loop for a zip tie,etc. Or you could offer up both the humped case half and the flat case half and let the owner/user decide.
#62
well i cant wait to see what the speedo will look like
#63
Most of all the questions have been answered by the Prez. This esc is awesome both the fx and the R1
Pictures of teh FX with the G-11 Pro second pic. R1 Pro with the G-11 Pro
#64
Should have seen the Little Mini Rage pushing around the rock crawlers they had. Pretty impressive for such a small unit
#65
#66
We're all looking forward to this!
#67
Will the BEC be good enough (clean enough 6v power) to run the KO 6V Digital servo's? I really want to run one again, but have not been able to with both my LRP QC2 and Novak GTX due to the BEC's not supplying enough voltage or the BEC power being "dirty". Capacitors didnt help either, even when I plugged one into the reciever.
Any ideas if it will work with these servo's as I really would like to run my KO high speed again.
#68
#69
Originally Posted by TRF415boy
I run a KO on my G11 and have never had an issue, and I would believe the BEC will be similar to the one on the G11 so you should be fine.
#70
Yeah there's a few of us on the team that run KO with the G11 pro's with no issue's at all either. Some of the older esc's had issues. Which Ko servo is it? Does it have the 7.2 v Fet wire? Those servo's should be hooked straight to the battery circuit as I'm sure you know. Those Ko servo's are power hungry but man are they fast...
#73
Do the R1 and the R1 pro have the Li-Po cut off like the FX series? I did not see it listed in any info that I have read.
#74
Does anyone have a good setup on speed control settings for the g-11 in modified>>>
#75
What class/car Rog?
